Bouncing Front End - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Bouncing Front End
Old 08-27-2013, 06:49 PM
saratoga2011's Avatar
saratoga2011 saratoga2011 is offline
saratoga2011 is starting off with a positive reputation.
Bouncing Front End
Any of you guys with the factory 20" wheels have problems with the front end bouncing at highway speeds?
I think I've got a bad tire to begin with. 7500 miles, I changed the oil and rotated the tires. It was perfect before, now on the highway if I hit a bump or change lanes, the front end starts bouncing and won't stop until I slow down below 60. Accelerate back up to 70, it's smooth until I hit an expansion joint or a rough patch then the bouncing starts again. Man I hope this isn't the Ford death wobble I've read about.
It goes to the dealer Friday, we'll see what they say.
Old 08-27-2013, 07:19 PM
GSSF17's Avatar
GSSF17 GSSF17 is offline
GSSF17 is starting off with a positive reputation.
Sounds like a bad tire or a tire out of balance.......
Old 08-27-2013, 10:48 PM
dualwheels66 dualwheels66 is offline
dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.
What air pressures are you running? First check your door jamb sticker for pressure recommendations then check your tire pressures. Sometimes pressures can be different from side to side causing a wobble. If pressures are good then I would think it is a bad tire.
Also Ford's shocks are crap from the factory.
Old 08-28-2013, 07:01 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
Is this bouncing up and down or a left/right shake (wobble)?
Old 08-28-2013, 08:32 AM
It's definitely an up-down bouncing in the front end and you can even hear it in the road noise. Something sets it off and it doesn't stop until I slow down which is what makes me think it's a bad tire.
The steering wheel doesn't shake or wobble.
On an unrelated note, the front tires were cupped before I rotated them... the rears were fine.
Old 08-28-2013, 09:27 AM
I wouldn't say it's death wobble then, probably a bad/out of balance tire as mentioned above.
Old 08-28-2013, 02:52 PM
sledjunk's Avatar
sledjunk sledjunk is offline
sledjunk is starting off with a positive reputation.
Maybe shocks, then?
Old 08-28-2013, 09:05 PM
The factory Rancho shocks aren't the best, I'll give you that.
This is definitely a tire. You can hear the LF wop-wop-wop-wop on the highway... I was able to listen with the window down driving next to some barricades tonight on the way home. I'm not too impressed with the Michelins.
Old 08-28-2013, 09:58 PM
sledjunk's Avatar
IIRC, isn't the scalloping that you had on the front tires a sign of a bad shock? You may have one problem causing the other. Just a thought. Hope I am wrong. Two problems are more expensive than one
Old 08-31-2013, 12:57 AM
It has a bad tire, took it in this morning and they drove it. Yep, it bounces/oscillates/vibrates so they road force balanced tires. All four tires had "high road force" so they balanced and "indexed" the tires.
I drove away with it tonight and the bouncing stopped but the drifting goes the other direction now because the fronts were swapped L-R. They agreed to replace the front two tires but have to get them from their vendor. Soooo I'll be bringing it back next week.
Old 09-01-2013, 09:59 AM
GSSF17's Avatar
At least they are making it right- good to hear. Thanks for the update.
4x4 F-550 rough ride at 60 to 75 MPH Michael Roark 1999 to 2016 Super Duty 9 06-27-2015 12:16 PM
Rear Truck Bounce sduce 1997 - 2003 F150 3 02-06-2015 01:10 PM
Bouncing when downshifting from 6th to 5th at ~60mpH zonedar 6.7L Power Stroke Diesel 2 10-27-2014 12:48 PM
Excursion Front end bouncing mkbishopsa Excursion - King of SUVs 10 08-06-2014 11:35 AM
Excessive bounce/hop while driving 97powersmoke 6.0L Power Stroke Diesel 6 05-13-2014 05:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
