Winter is coming - weight in pick-up bed - Ford Truck Enthusiasts Forums
Old 08-27-2013, 08:34 AM
joegeds joegeds is offline
joegeds is gaining momentum as a positive member of FTE.
Despite the fact that we'll reach 90 degrees today here in the Motor City, winter is on it's way. This is the first winter I will experience with a pick-up truck. I'm wondering what I should expect in terms of handling on the ice and snow, and also if any of you put weight in the back of your truck. If you do, what do you use for weight, how much weight, and where do you put the weight?
Old 08-27-2013, 09:02 AM
blue924.9's Avatar
blue924.9 blue924.9 is offline
blue924.9 is starting off with a positive reputation.
right over the axle, dont know how much and i use anything that is heavy
Old 08-27-2013, 09:27 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
2wd or 4wd?
Sandbags are ideal as they won't become an unnecessarily dangerous flying hazard in the event you get in an accident.
Anything smaller than an ext cab 4x4 will definitely need weight in the bed, and 200-300lbs will make a big difference in traction but a good set of tires will also be necessary if you want to be able to stop effectively.. which is actually the bigger problem. To that end dedicated winter tires are best but an aggressive all terrain is also good as long as it has a narrow profile, meaning those 10.5 and 12.5 tires that many like make the worst winter tires.
Old 08-27-2013, 09:36 AM
blue924.9's Avatar
Quote:
Originally Posted by Conanski View Post
2wd or 4wd?
truer words have never been spoken, that said i love the way my mastercraft a/t2s look, and even though they are wider they still work decent in snow and ice, even with my 2wd er cough couch 1 wd
Old 08-27-2013, 09:57 AM
2wd or 4wd?
Oh yeah - sorry. I should've learned by now to include the specs for my truck: '96 F150 4x4, 4.9 straight 6, manual 5-speed. Why would a narrow profile tire be good in the snow? I would think you would want a wider tire for more traction?
Old 08-27-2013, 10:05 AM
blue924.9's Avatar
no, it floats on top and never sinks down and bites, that being said my buddy has an avalanche with way wide tires, like 15 inch wide ones, its a beast in the winter, stops well and when that thing spins the tires it cuase its on ice
Old 08-27-2013, 10:57 AM
Jarryd's Avatar
Jarryd Jarryd is offline
Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.
I forgot all about winter. My 12.5s and open 3.08 rear are going to get me stranded. I need to get the ball rolling and do this 4x4 conversion. We don't really get snow here though.
Old 08-27-2013, 11:04 AM
Nothing Special's Avatar
Nothing Special Nothing Special is offline
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
Sand bags are good as already stated. Plus the sand can be used for traction if needed.
I've had fiberglass toppers on most of my trucks so I've pretty much left it with that. But even my first truck ('85 F-250 standard cab) wasn't too bad with no added weight. It just needed 4WD pretty often.
Old 08-27-2013, 11:19 AM
gasman6674's Avatar
gasman6674 gasman6674 is offline
gasman6674 is gaining momentum as a positive member of FTE.
I use rock salt because when I carried sand it was always frozen when I needed it. Then when winter is over I dump it in my water softner
Old 08-27-2013, 12:02 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant future
Quote:
Actually joe, by now you should have those specs in your signature, that way you won't need to re-post them everytime you ask something, to do so just click the "User CP" button up there, then click on the "Edit Signature" button and fill in the space.
With snow you either have to get slim-profile tires or monster-size tires, that's what's used in Iceland out on the field, 40-44" tires on specially modified Ford and Toyotas.
Old 08-27-2013, 12:14 PM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i don't use any added weight.
at 9,000 lbs on the 88 and 79oo lbs on the 02, i don't need it.
and if you know how to drive it is not really needed either. i go places in my crown vic that others with 4X4 get stuck in.
Old 08-27-2013, 12:19 PM
blkF250HD's Avatar
blkF250HD blkF250HD is offline
blkF250HD is gaining momentum as a positive member of FTE.blkF250HD is gaining momentum as a positive member of FTE.
I always thought this was a cool idea:
ShurTrax All Weather Traction for Car, Truck, SUV and CUV's Shurtrax Store
I've never tried it or seen one in person, but it makes sense. I may go the rock salt route this winter, ext cab long bed trucks are kinda iffy when it's really slick out.
Once you get used to driving it and correcting for oversteer and skids you'll be fine. Find a large, empty parking lot and put the truck into some skids to learn how to recover and get a feel for how it behaves.
Old 08-27-2013, 12:26 PM
blue924.9's Avatar
seen those, cheaper just to throw some random stuff in there or some sand, i know one guy who filled his bed halfway with water and let it freeze
Old 08-27-2013, 12:36 PM
mont974x4's Avatar
mont974x4 mont974x4 is offline
mont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to behold
Using gravel or sand bags for weight is a great deal. They have the added benefit of being useful if you have to cut one open to put under a tire or two if you're stuck. Kitty litter would work the same....I suggest whatever is most cost effective in your area.
As to tires? I had Cooper Discoverer STT's on my F-250 CC and (and they were wide) and only had to use 4wd when the snow got deeper than 14 or 15 inches. Remember ground clearance needs to be considered as well. I also put pretty beefy Discoverer ST's on my brides expy and they do well too. These tires are siped (sp?) for added traction on ice.
You don't necessarily want to cut down through snow as it allows more traction than the ice under it. Remember snow shoes are wide for a reason. Wind polished ice is way more of an issue than snow.
Old 08-27-2013, 01:53 PM
garrett_8 garrett_8 is offline
garrett_8 is starting off with a positive reputation.
if it snows enough thats enough weight in the bed, if not thats why god made 4x4
Winter Weight box Diesel_Brad Ranger & B-Series 7 01-20-2011 04:31 PM
How much weight do you add for winter driving? DBGrif91 1987 - 1996 F150 & Larger F-Series Trucks 29 12-21-2009 10:06 AM
Weight in-bed for Winter Traction 6CylBill 1987 - 1996 F150 & Larger F-Series Trucks 102 10-25-2009 01:48 PM
Adding Weigth During Winter helix-2000 2004 - 2008 F150 27 02-14-2005 02:20 PM
4x2 Winter Driving ?? Katmandu2 1987 - 1996 F150 & Larger F-Series Trucks 11 08-26-2003 08:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
