M50D to a ZF5 - Ford Truck Enthusiasts Forums
M50D to a ZF5
Old 08-27-2013, 02:08 AM
Swoop03's Avatar
Swoop03 Swoop03 is offline
Swoop03 is starting off with a positive reputation.
M50D to a ZF5
I have an 88 F250, 302 4x4 with the light duty 5 speed. I really would like to swap over to a Zf5 tranny. The mazda's gears paired up with 3.55's is just to steep for a truck in my opinion.
Assume that I have nothing but the ZF5 and Transfercase. Nothing more.
I'm looking for a list of parts I'd need to bolt the zf up to my 302. I found one from a 351w and to my understanding the bellhousing pattern is the same. The only problem is that I only found the tranny and transfercase. I'm pretty sure it doesn't have anything else with it. I'm waiting on a reply for that.
So is my flywheel, clutch and splines and all that the same as the ones used on the ZF? I know I will need the drive shafts and I can get them without a problem. What about a slave cylinder? The mazda has an internal one, what will I need to do for the ZF setup? Will my crossmember work? Tell me everything I need to know. I haven't been able to find enough information to satisfy me on the internet so far. Also if I happen to need parts for the zf do any of yinz know a good place to go and order them when the time comes?
Thanks in advance for your help.
Old 08-27-2013, 02:48 PM
Daniel5.0's Avatar
Daniel5.0 Daniel5.0 is offline
Daniel5.0 is gaining momentum as a positive member of FTE.Daniel5.0 is gaining momentum as a positive member of FTE.
Mostly subscribing, but I have a couple things to add.
Overdrive is actually a higher gear with the ZF. All others are, indeed, lower.
My guy at NAPA was not able to get me bearings and seals through his normal channels. He had to special order from a local transmission shop. If you know of a good shop, you may want to go directly there. The kit I ended up with is a Motive Gear T300ZRA.
Old 08-28-2013, 05:57 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
The bearings should be the same as the 351, the flywheel will be different as it has a different balance weight. Use the clutch and all related parts for the 351 truck.
Old 08-29-2013, 05:36 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
The clutches are the same. I re-used the original 302 clutch (and flywheel) in my truck when I swapped in the ZF.
I don't know if the slave cylinder/release bearing is the same as the one on the Mazda or not, but it's not a bad idea to install a new Motorcraft slave cylinder while the transmission is out and the slave is easy to get to.
I only have experience with a 4x2 ZF, but I have read on here that the difference in length between the 4x4 Mazda and 4x4 ZF that you can re-use your original dirveshafts. The crossmember is the same as far as I know.
Old 09-19-2013, 02:09 AM
Swoop03's Avatar
Thanks, i don't have the tranny, i never got a hold of the guy and the add is gone now but the information is still here. Thatll be a later swap anyways. While i got the tranny out ill probably go over the frame with a wire wheel and paint it or treat it somehow, have a custom exhaust welded up, i know a guy that has good prices, and whatever else i decide later on. So far my mazda is holding up to my work truck despite all the negativity i hear about them. It gives me a noise here and there and will act funny per say. But it still works. Ill be checking the fluid this weekend.
Value of used ZF5 and BW1356?? Pheadrus Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 03-31-2014 04:13 PM
help zf swap 460 what flywheel to use ralphatlarge 1967 - 1972 F-100 & Larger F-Series Trucks 1 12-28-2010 07:51 PM
zf 4x4 will it work mach6-300 Ford Inline Six, 200, 250, 4.9L / 300 11 07-11-2010 03:06 PM
C6 to ZF5 (460) Build Report jbrown9709 1973 - 1979 F-100 & Larger F-Series Trucks 1 05-02-2009 02:47 PM
mazda 5spd to zf 5 spd MeBadDog2002 Clutch, Transmission, Differential, Axle & Transfer Case 7 04-29-2004 10:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
