5 inch rear springs drop
Old 08-26-2013, 10:46 PM
roshan's Avatar
roshan
roshan is offline
My title caught your attention didn't it ... These are on my 52 M3... Well.. I left the first 3 springs, then removed alternate ones for the next 3 and removed everything else. Pics show before and after. ... It dropped from 6.5" to 1.75".
Let me know if you have any comments/concerns. This is my first major build so I can def. use tips.
My work area:
After U-bolts came off:
After extra leaves came off:
Original leaves:
After removing extra ones:
Old 08-26-2013, 11:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Are you keeping the stock axle?
Old 08-26-2013, 11:51 PM
roshan's Avatar
roshan
roshan is offline
No. The rear end that u see sitting behind the truck is a dana 60 .. the one on the right is the old timken ... I'll be bolting in the dana 60 tomorrow..
Old 08-27-2013, 01:55 PM
aussiecowboy's Avatar
aussiecowboy
aussiecowboy is offline
This is a job generally best done with the bed and everything installed on the truck, otherwise you don't know where the final ride height will be when all the weight goes back on. Don't throw the leaves away, you might need to adjust a bit more yet.
That right hand jack stand in the first pic looks a bit of a scary angle!
Old 08-27-2013, 02:01 PM
roshan's Avatar
roshan
roshan is offline
I have actually saved all my springs. This is just a first mock up. Need to take them off, sand them, put rust deterrent and a graphite paint on them. About the bed, you're right. I wont know the exact ride height until all the stuff is loaded on top of it.
Yeah I noticed the jack stand yesterday.. it moved a bunch when I dropped the rear end. That's not too hard to fix . I'm gonna try and finish up the rear springs today, mount the dana 60.. and try doing my brake lines today evening.
Old 08-27-2013, 02:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'd be worried about the effect of the heavy D60 (or the stocker, for that matter) on the springs when you hit a bump. Ride height isn't the only factor to consider.
Old 08-27-2013, 02:04 PM
roshan's Avatar
roshan
roshan is offline
Would you recommend adding in a couple more of the smaller springs? I guess theres only one way to find out what would happen when I hit a bump with the dana 60
bigdog660
07-09-2016 04:00 PM
Lil Red Sled
11-05-2012 05:29 PM
Newcomer
Offroad & 4x4
28
08-05-2012 06:57 PM
AlaskanEx
12-03-2010 02:57 PM
Quick Reply: 5 inch rear springs drop
