4x4 or low rider
Read these and let'em serve as either your warning or motivation:
2WD to 4WD Conversion
4WOR Magazine: Project Two-by Four (4x4 Conversion)
FTE Thread: Quadrazer's F350- 2WD to 4WD Conversion...
In my opinion, the input-to-output ratio of work, time, and effort to convert a 2WD to a 4WD isn't worth it. If you want a 4WD, I think you're better off having the configuration to start with rather than working to get the configuration.
Start a thread and call it "the Lo-Buck Dentside". Use salvage yard, bartered, used, and lo-buck parts to have a clean rig at the lowest cost. Showcase to us that it can be done with a low budget, good workmanship, and dependability. Of course, have fun with it.
Well I was thinking about leaving it a 2x4 but I wanna kno if anyone had any thoughts on rat rodding it chopping the top but not wanting 2 do the whole clear coating over rust n all that it's 4 the most part strait n paint is all good n it's mostly rust free I would like other ppls opinions on it as well.
Leave it stock or nearly stock on the outside (cleaned up of course) but super-build and detail it underneath.
Go 'sleeper' instead of ratty... leave the rat-look to the lemmings who follow whatever the most current trend is in at the time. Make and follow your own path.
Build a clean and retro farm truck that can haul the mail, haul the hay, and haul some azz.
fordguy300
10-20-2008 09:14 AM
hutch75
11-16-2007 08:33 PM
