Spicer 24 Lubrication
Hi all,
Those of you that are 4X4 owners, what have you used for lube in the Spicer 24 divorced transfer case? My old Ford literature only mentions 80W or 90W (depending on temp range) for the T98 four speed trans but nothing for my transfer case.
While doing a search, another post mentioned using 50W. I'm unsure what to use now in my restoration project.
Whatever the general rule of thumb is, can i use it in both the transfer case and the transmission?
Nick in WI
Nick in WI
Thanks Buzz44,
That's what I ended up pouring into both the trans and transfer case last night in the absence of finding straight 90 weight.
This truck too will be only used when the temps are above 40F. My floats are set way to high on the Holley 600 so it didn't get started for the first time last night. Truck project to continue after Harley's 110th wraps up...
Nick in WI
Nick in WI
Can DO
02-17-2009 06:17 PM
Kenny
10-09-2000 02:22 PM
