new 7.3 owner here
new 7.3 owner here
Hi there folks, first post here, I live up in northern alberta Canada. I just recently purchased a 95 F350 with the 7.3, 5 speed manual tranny, 179000 km's. Has some issues, when a rev it up in neutral it smokes and sputters approx 2000- 2500 rpm...low end power seems ok, starts ok too as long as I glow plug. It when cold.
I've read A LOT of uesfull info on here already,but I figured I would ask the experts before starting to trouble shoot.
BTW fuel filter is changed.
Thanks
Thanks
Welcome to FTE!
Couple of questions:
Does it do this when your driving it or just when your sitting there in neutral?
Does it have a chip or programmer?
If you get a chance post up some pics! You will have to upload them to photobucket or flikr and link them back here, we all love pics around here!
Once again welcome to FTE!
Crank position sensor. Always carry a ford/IH one in your glovebox along with a 10mm socket and ratchet.
Riffraff Diesel: Motorcraft CPS 94.5-03
I have never had to change one but this is one of the first things to try when the engine starts having issues.
The PSD is pretty simple as far as common rail diesels go. Not a lot will stop them but the CPS is one of those things. It is apparently very easy to change... As I said i have never had to though.
Richard
EDT: I figure check the fuel pressure first cause it's a cheap and easy check.
Richard
on
1 Post
Thanks
Thanks
CPS is the CAM position sensor (there is no crank position sensor). As said, required glove box content.
Chip check - remove the fasteners for the parking brake handle assembly (leave the cable attached) and move the assembly toward the right side of the truck, away from the cab wall. You'll see the PCM sticking into the firewall from there. The chip will be plugged into a socket in an opening in the aft end of the PCM, if one is there.
