Oil filter standpipe damage pics from FDDTS
Old 08-25-2013, 09:36 PM
bismic's Avatar
bismic
bismic is online now
Received 2,478 Likes on 1,718 Posts
Here are some interesting pics from FordDieselDoctor (FDDTS site)
Melted standpipe - cheezit (some time ago) noted that this starts to happen around 270-300 degrees F and melts completely at 350 degrees:
Melted Oil Standpipes - Oil And Water - Gallery - DTS
An older FTE thread on a melted standpipe:
https://www.ford-trucks.com/forums/1...standpipe.html
Damage from non-OEM filters:
Non-OEM Filters - Oil And Water - Gallery - DTS
and this - (see warning at bottom) -
http://alliantpower.com/sites/allian...b_03-09_en.pdf
Filter installation damage:
Oil Filter Installtion Damage - Oil And Water - Gallery - DTS
Also:
http://www.thedieselstop.com/forums/...hanism-306969/
http://www.dieselpro.ca/tech-info-6.0L-Filters.html
Old 08-25-2013, 09:45 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
Photo proof for the reasons discussed here on why to use OEM filters!
Thanks Mark
Old 08-25-2013, 10:02 PM
bismic's Avatar
bismic
Maybe Rich (lilpooh) won't mind me posting links to his pics!!! Here is a summary of his assessment on a "well traveled topic":
"Stopped to see Dale at the dealer. Showed me two filters that were on customers trucks. First pic, filter on left is Baldwin. Filter in middle is Motorcraft, filter on right is WIX.
Baldwin filter is shorter, has spring in center section, and broke the top section of oil filter stand pipe!! WTF. The WIX filter wasn't long enough, for the WIX oil cap, so it didn't seat the anti-drain valve!!
Lesson for today..... Stick with Motorcraft or Racor!"
http://i598.photobucket.com/albums/t...95A70136E1.jpg
http://i598.photobucket.com/albums/t...3C5A6C87-1.jpg
http://i598.photobucket.com/albums/t...957C0D805F.jpg
http://i598.photobucket.com/albums/t...959FC7A062.jpg
http://i598.photobucket.com/albums/t...9598D39D71.jpg
Old 08-25-2013, 10:10 PM
big inch's Avatar
big inch
big inch is offline
I have only seen one melted standpipe, and it was completely gone. When I contacted the Hotline to get approval to replace the engine, they told me the oil temperature would have to have been over 350 degrees in order to melt the standpipe. It is hard to believe the engine would have run at that temperature, but evidently it did.
Old 08-25-2013, 10:13 PM
PartsPaul62's Avatar
PartsPaul62
PartsPaul62 is offline
That's why Ford Motor Co. recommends Motorcraft Brand parts. Designed and built specifically for Ford Motor Co. vehicles.
elishaman
1999 to 2016 Super Duty
08-11-2019 12:15 PM
smokersteve
04-14-2013 07:08 PM
fordboy_52
Oil & Lubrication
13
07-20-2005 06:44 PM
Dunk
Oil & Lubrication
08-19-2004 12:39 AM
Quick Reply: Oil filter standpipe damage pics from FDDTS
