My buddy says its a EGT sensor, and although ive never heard it mentioned or that it exists, its about the only logical thing. Sure as hell aint an 02 sensor lol!!
Yep thats the exhaust back pressure sensor and tube,take the tube off and clean it sometime it will help a bit with mpgs and performance, i was shown that and i did it and it made a difference, i was told to clean it with a cable like you see on pedal bikes used for brakes and i was told to push it in there and run it with a drill which worked good but it was tough to get in the tube since it was full of carbon, i used wd-40 to help with that and ran it for a few a couple of times and got it all cleaned up then i cleaned the wd out with brake cleaner i didnt know if i needed to but i did.
When i got the truck the wires for the sensor were cut out of the harness...so i take it it doesn't matter if i clean it or not lol?
Hahaha on that one i dont know, i bet if it was hooked up and working good it would sure make it run better but im not sure, i wouldn't think it would matter with it cut i wonder why they cut those wires, maybe there is something i dont know about that cutting the wires does hahaha but i doubt it, maybe someone else may pick this one up and fill us both in on that hahah, i do know with mine unplugged it made my truck throw a (CEL) Check Engine Light.
As a matter of fact a lot of random things were cut out or broken off, but its always ran fine and never thrown a CEL
