Truck temps while towing in hot weather - Ford Truck Enthusiasts Forums
Old 08-25-2013, 03:31 PM
952X4's Avatar
952X4 952X4 is offline
952X4 is starting off with a positive reputation.
I was towing the 5er (about 15000#), across Southern Mn and SD today going right into a 20-25 mph wind in upper 90 temps, saw 228 on the oil temp and 199 on the tranny temp. Wondering what some of you guys who tow see for warmest temps and at what point you start to get concerned...
Old 08-25-2013, 04:36 PM
Painted Horse's Avatar
Painted Horse Painted Horse is offline
Painted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud of
Climbing 7% grades, I frequently see 242 and that may last for 10-20 minutes as I climb. Once over the summit it drops pretty quick back to the low 200s. Coming home from Jackson Hole pulling a load of horses Saturday it stayed at 208 most of the trip, and the outside temps were 53
Old 08-25-2013, 06:55 PM
mikethomas mikethomas is offline
mikethomas is starting off with a positive reputation.
I asked this same question in another post about a month ago. I have seen engine oil temps in the neighborhood of 230 when pulling a 12,500 lb trailer up a 10 mile 6% grade. The temp dropped quickly once I crested the grade. I was also told that the fans come on at 240.
I watch my temps pretty religously and they usually run around 200+/- for engine oil on flat ground and around 190 for the trans temp. The engine water and trans temp guages on the dash don't seem to move at all once up to running temps. When pulling short steep grades it is common for me to see 215 on the engine oil temp.
Mike
Old 08-25-2013, 07:49 PM
Karl4Cat's Avatar
Karl4Cat Karl4Cat is offline
Karl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputation
Towing the toyhauler into the Adirondack's this summer in 95+ we hit the high 240's and over 200 on the trans. As stated above, dropped very quickly after cresting the hills.
Old 08-25-2013, 10:42 PM
jimmystoys's Avatar
jimmystoys jimmystoys is offline
jimmystoys is gaining momentum as a positive member of FTE.jimmystoys is gaining momentum as a positive member of FTE.
I agree with you guys. My oil temps have reached almost 250 when towing or when I'm pushin pretty hard!! but I tell you, it cools down quickly too. Something my 6.0l never did. I had to stay off it, a lot, even goin down hill!, then..... Now, my trans runs just under 200. The oil, usually around the 200 mark. I think 200-235 towing would be considered normal. I've been told these engines are designed to run hotter. But are designed to cool down quicker and I have witnessed that! I'm finally impressed with Fords new engine.
Old 08-26-2013, 02:46 PM
You have two cooling systems on this engine. The Oil Cooler is located on the Primary Cooling system.
You have two Thermostats on this system. The 1st opens at 194F and the 2nd Opens at 201F
So if the cooling system is keeping up, your oil should be in the 201 range. It would be rare to see it below that temp.
So when we climb grades, the oil temp climbs as the oil does it job of helping to cool the engine. It will quickly drop down to the temp of the coolant as soon as we stop producing excess heat.
The flash point on most oils is well into the 400 range, so temps in the 200-250 are with in working ranges.
Old 08-26-2013, 04:54 PM
marchare011's Avatar
marchare011 marchare011 is offline
marchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant futuremarchare011 has a brilliant future
Good info PH. I like to follow your posts about the cooling systems.
I routinely see 242 degree oil temps pulling my toyhauler up the mountains here in WY and SD. The last time I weighed my truck and 5er, we were just a tick under 30K. Two weeks ago me and ma headed up into the Big Horn Mtns (6-7% grades), and we were loaded up to boondock for 8-10 days. Extra fuel, water, long term supplies. I am always happy with the performance of my dually dragging that anchor up the hill at 55mph. At 242 degrees, the aux fans come on and quickly cool things back down. If I keep my foot in the pump, the fans stay on and decrease and increase speed and intensity as needed to stay cool. Tranny temps usually hang around that 199-203 range under same towing condition.
When we were coming off the mountain, there was an older model Chevy dually gasser pulling an older model 5er up the hill and he had about 10 cars stacked up behind him and climbing at about 15 mph. I would like to know what his coolant temps were running. I think FOMOCO did a good job with the cooling system, except for the problem child leaking radiators.
Old 08-26-2013, 05:26 PM
WildWildWest's Avatar
WildWildWest WildWildWest is offline
WildWildWest has a great reputation on FTE.WildWildWest has a great reputation on FTE.WildWildWest has a great reputation on FTE.WildWildWest has a great reputation on FTE.WildWildWest has a great reputation on FTE.
I have been on the road towing for the last four weeks in temps up to 98 degrees pulling 8% grades through Montana, Utah and South Dakota. Regularly pushing 234 to 238 on the grades with 12,500 lbs behind her. Hit 244 a couple of times and as others have said it quickly dropped down after reaching the crest. I monitor my oil temp on my MiniMaxx so it is easy to keep track of it. Never broke 200 on the tranny once. Never dropped below 60 mph.
Old 08-27-2013, 09:52 PM
porthole's Avatar
porthole porthole is offline
porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.
Quote:
I see those numbers all the time, 36' 5th wheel at 17K +
Old 08-27-2013, 10:09 PM
desertnomad's Avatar
desertnomad desertnomad is offline
desertnomad has a good reputation on FTE.desertnomad has a good reputation on FTE.
Yep, see these temps all the time towing and a few times hit 245* on a 100* day climbing 6-8% grades but chills right back down after cresting the top.
Old 08-29-2013, 11:52 PM
Davgt500's Avatar
Davgt500 Davgt500 is offline
Davgt500 has a good reputation on FTE.Davgt500 has a good reputation on FTE.
I to see the temps mentioned above on a daily basis, I am sure that the computer will shut you down if temps get to high, I have not experienced this in these trucks but have in semi's.
need engine temp and tranny temp gauge help slinginsaws 1987 - 1996 F150 & Larger F-Series Trucks 5 10-28-2014 04:12 PM
Oil Temp alert from Edge Insight donovan 6.7L Power Stroke Diesel 15 06-18-2013 04:04 PM
Oil Temp Towing travlingman 6.7L Power Stroke Diesel 8 04-20-2012 11:00 PM
High EOT when towing?? mgood 6.0L Power Stroke Diesel 12 02-28-2012 05:28 PM
Engine Oil Temp. 2010F350 6.4L Power Stroke Diesel 14 11-29-2011 08:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
