welding tips - Ford Truck Enthusiasts Forums
welding tips
Old 08-25-2013, 01:33 PM
scoobyvanjack scoobyvanjack is offline
scoobyvanjack is starting off with a positive reputation.
welding tips
Need some insight on getting the warps out of a flat panel repair.
replaced the bottom 4" of a door skin and had to replace a 4x8 in. section in the center of the same door. I skipped back and forth across the butt seam so as not to over heat a particular area. On any of the curved or crown areas prviously welded the shape of the metal has not had the same result. The only thing I can think to do either planish the welds or cut it all out and start over and maybe backing up the edges of the seams with a strape of 1/8" steel tacked on to help hold the shape. Any insight on the would be greatly appreciacted.
svj
Old 08-25-2013, 08:50 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Without pics it's a little tuff, but, you can cut (with a blade or cutting wheel) the edge of the panel where the warping is...probably on two planes/edges...so these can act as a relief cut to allow the panel to return to its original shape (caused by the metal expanding under heat)....then instead of welding, braze it back...1/2 the heat more than adequate strength.
Old 08-25-2013, 11:20 PM
warped panel
unfortunately I'm a bit on the short end to buy a welding rig any time soon. I'm bumbling along with a cheesy harbor freight flux core welder. Over time I've gotten fairly adequate with it but your right its much hotted than oxy-acetylene
and with only 2 voltage settings you learn to play games with the feed rate and wire gauge.
Today I planished the seams hammer on dolly and it's getting better. I hit the ridge from the inside with a bead and it shrunk it down far enough I could work it with a pick hammer off dolly ever so gently. I still have a bit of tin canning but some of it will be hidden behind the licence plate presuming I can recreate the door mounted tag lamp assembly.
But thanks for the tip I may throw the gas tank back in it and run it down to the
shop I wright service at and try it on the side patches I was going to cut them out and start over but this sounds like it's worth try.
Thanks again
svj
Floor Board replacement - weld placement ktgovols 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 07-13-2016 01:50 PM
1962 uni big window v8/com shorty structure Koolkat 1961 - 1963 F100 Unibody 0 03-17-2015 03:09 PM
Rust repair and patch panel forming AXracer 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 12-02-2014 12:43 PM
Filling in seam on back of cab 4x4jedi 1967 - 1972 F-100 & Larger F-Series Trucks 7 03-31-2010 10:17 AM
Retubing Dana 60 Front Axle averagef250 Clutch, Transmission, Differential, Axle & Transfer Case 11 08-15-2009 10:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
