My 1st restoration project 1966 Ford f100
Old 08-25-2013, 12:00 PM
Daboy's Avatar
Daboy
Daboy is offline
Loaded up and ready to go home.
Extra heavy duty front cab mounts. LMAO
Not a terrible platform to start on I guess.
It has the 3 speed with the overdrive. I will not be using it, I do now reverse and forward gears are fine but not sure on the OD part of it. The vehicle is not licensed to find out, and even if it was I wouldn't know how to use it.
Oh and door plate,
Old 08-25-2013, 12:07 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Ziegelsteinfaust is offline
Nice looking start.
Old 08-25-2013, 01:12 PM
Faber's Avatar
Faber
Faber is offline
Hey someone whom can post pics.... Sweet....
Yeah, looks like a good start. I'll be interested see rust damage extent once get into her....
Old 08-25-2013, 05:41 PM
cvcman's Avatar
cvcman
cvcman is offline
How would you fix those cab mounts ?? Did you get the truck reasonable ?
Old 08-26-2013, 06:09 AM
ddavidv's Avatar
ddavidv
ddavidv is offline
F10 = F100
Y = 352 V8
L = Michigan assy line
882951 = built June 1966 (next to last month of production)
Color A = black
E81 = body trim...this code isn't on my chart but looks like you've got a legit Custom Cab
Trans B = 3 speed with overdrive
Axle 08 = 3.50 rear end ratio
Old 08-26-2013, 08:58 AM
Daboy's Avatar
Daboy
Daboy is offline
I will say this. It doesn't look bad from the outside but underneath it is in bad shape. Even the the rear cab mounts are rotted out. Not the mounts on the frame but the support rail ( not sure what it is called) that mounts the rear of the cab to the frame. Going to be over my head I am sure a few times, but thats what the internet is for right? LOL
Old 08-26-2013, 09:03 AM
Daboy's Avatar
Daboy
Daboy is offline
There will be alot of cutting and grinding for sure. My metal skills are going to get drastically improved! I gave $1000.00 for it but I hope to recoup some $$$ with the sale of the 3 speed with O/D trans.
Old 08-26-2013, 10:02 AM
Faber's Avatar
Faber
Faber is offline
lol....yep, thats pretty much what i did....got on the internet, bought a book, started learning....still learning. I enjoy it.
Sounds like your price paid was pretty good....
Old 08-26-2013, 11:38 AM
Daboy's Avatar
Daboy
Daboy is offline
The lighted Bull horns have to be worth 3/4 of the purchase price!
The electric window add on also! (These do not work by the way)
The black box that is mounted on the inner fender is cruise control! Not sure if this works.
This ole girl definitely had some red neck engineering in its day.
Old 08-26-2013, 07:22 PM
Faber's Avatar
Faber
Faber is offline
dibs on the lighted bull horns!
Old 12-06-2013, 05:54 PM
Daboy's Avatar
Daboy
Daboy is offline
Progress update.
Donor truck with 390 and c6 auto that I will be using plus the steering column.
Rotted floor pans.
Cab off and waiting for floor pans and front cab mounts to start the cutting process.
Old 12-06-2013, 06:15 PM
Faber's Avatar
Faber
Faber is offline
Awesome....
88beast
474
07-17-2019 08:54 AM
MNTBUGGY
39
01-09-2019 06:07 PM
nlareau
81
07-19-2014 12:41 PM
jasmyers1
08-14-2012 09:46 PM
relient3074
06-28-2008 01:22 PM
Quick Reply: My 1st restoration project 1966 Ford f100
