Cheap 460 performance Ideas? - Ford Truck Enthusiasts Forums
Old 08-25-2013, 11:36 AM
MTRN92 MTRN92 is offline
MTRN92 is starting off with a positive reputation.
Hey Guys,
So Ive got a 460 EFI that I need to rebuild. After doing new rings and bearings and seals i plan to do some mild and cheap performance and was just wondering what some of your ideas were. Right now I have a different air intake, Smog controls deleted, a heavy duty clutch and a straight exhaust. But other than that nothing. My plans Right now include:
90's Mustang ECM.
Mild Cam
MAF conversion.
Advance timing a few degrees.
Does anyone know if the rumor about putting the 90 Mustang ECM on the 460 wakes it up?
What about cam recommendations?
As for the MAF conversion, i am going to do it myself. so what parts do i need? i am not buying a ridiculously expensive kit. just gather the parts and rig it together.
Thanks,
Montana Redneck
Old 08-25-2013, 11:57 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
What year is you truck?
The first thing on your list should be opening up the intake and exhaust systems, Ford installed some rediculous air horns in the intake tubes on these motors so get those cut out, and the whole exhaust system especially the manifolds need to go away and be replaced with headers and 2.5" tubing.
As for converting the truck to MAF the Mustang ECU can be used but only if the truck has a C6 or manual trans, if it has the E4OD that's a complete no go. Using a Mustang ECU will require a tuner though since that box is programmed for a 5.0 and 19lb injectors, the tuner of choice these days is the Moates Quarterhorse with Binary Editor software on a laptop, total cost for this is about $400 excluding the laptop but it gives you complete access to all parameters in the EFI system so you can run any combination of injectors and MAF meter on any motor.
Old 08-25-2013, 12:06 PM
Evan_P's Avatar
Evan_P Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
The EEC thing isn't a rumor, But it isn't as simple as putting it in. You MUST to have a tuner for the EEC to tweak it to run the 460, otherwise it will run WAY worse with the EEC. You will also need a stand alone trans computer if you have the E4OD.
As for the MAF, your gonna be tested when it comes to finding parts. There were very FEW 460 trucks made with a MAF setup. You need the ENTIRE air box and hoses, the MAF sensor and then you will need a MAF EEC, preferably one with a J3 port for tuning. On top of that, you need to either harvest the injector and MAF harnesses from a donor, or go buy the MAF harness from RJM for $200. Once you have those, you have to re-pin the EEC connector at the firewall.
A MAF upgrade is not easy, but the benefits if you do it right are well worth it. If you find yourself an EEC that is MAF with a J3 port for tuning, you can pretty much upgrade the engine as much as you want, tune it and it will run just fine.
Here is the RJM harness:
RJM Injection Tech — Truck SD to MAF Harness
Here is what a J3 port looks like:
And here is a wealth of knowledge on fuel injection and MAF stuff:
Fuel Injection Technical Library
*Edit: Paul beat me to it...
Old 10-16-2013, 06:05 PM
Thanks for your responses guys. I blew up the motor last weekend so right now im doing a rebuild, (porting heads too) and putting in a Dana 60 up front. ill post photos as soon as its done. As for the truck: its a 1990 F250 with a 460, ZF 5 spd, 5 inch lift with 37s. straight exhaust.
Thanks a lot guys. youve helped a bunch.
460 mass air conversion rdbcole1956 1987 - 1996 F150 & Larger F-Series Trucks 12 09-02-2014 02:58 PM
EFI 460 Performence questions 93f250tn 1987 - 1996 F150 & Larger F-Series Trucks 6 02-23-2013 02:54 AM
TwEECer RT 85lebaront2 Computer Chips & Tuners 5 06-05-2012 04:18 PM
460 MAF Conversion in CA? GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 6 05-22-2012 07:49 AM
MAF conversion questions mikehawk 1987 - 1996 F150 & Larger F-Series Trucks 15 04-18-2010 03:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
