Help to remove 1992 Ranger OEM Radio - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-24-2013, 05:08 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
SO back playing with the ranger and Got A New Stereo Deck
I have the Dash Trim Off around it
dO I press something into the 4 small Holes in the Radio??
Started to rain so thought I would investigate
thanks Guys
Old 08-24-2013, 05:24 PM
BLADE35's Avatar
Was it the 2 U Shaped Remover Tools??
I think I have a Set
Found them With my Last Ford Deck I pulled LOL
There in and Still stuck I pretty shure I will get it
Need to pull them back a Hair I think
Old 08-25-2013, 07:58 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
You have to insert them, and then use them to disengage the factory catches. You don't just stick the tools in and pull.
Old 08-25-2013, 11:47 AM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
4 very small allen wrenches inserted in the holes will do the job in a pinch.
Old 08-26-2013, 09:17 PM
BLADE35's Avatar
Thanks for the Help
I had the Remover tools They was in tha Last Ford deck I pulled
This Ranger is the First truck I Found Stereo Speaker wire clear up by the Headlights
The truck had been in a Wreak and driver door was changed It Had No 6" Speaker hole Like passenger side did so I had to cut that In
I took the factory harness and cut it at the headlights fished it out of there and used the Wire Loom to route into Both Doors Like my F350 is Kinda
It was a 2 day deal LOL
My Problem Now is the Stereo Deck I THINK
It Needs More Trebal it don't hit the High notes like it should
The stereo deck was Clearance at Walmart My Mother in law bought it has a USB and only 1 Preamp out
There is NOT the control or Eqaulizer in it Like my Pioneer has
That's all I can really think a Better Deck would help
Should I get a New Deck??
Aftermarket stereo w/ original DVD & monitor Rushmore X Excursion - King of SUVs 44 03-18-2017 01:17 AM
Replacing stock stereo with rear DVD RRTREE Excursion - King of SUVs 1 03-30-2014 08:01 PM
some simple stereo (6 disc)questions on my 04 fx4 jagarcia89 2004 - 2008 F150 19 03-02-2014 05:59 PM
Stereo in 1999 from 2008 scottblogs 1999 to 2016 Super Duty 2 01-02-2014 12:15 AM
Churchill Technology???? sailmfast Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 05-19-2013 06:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
