87 f150 body mounts
Old 08-24-2013, 04:17 PM
fordka's Avatar
fordka
fordka is offline
87 f150 body mounts
Id like to put new body mounts on my truck while its apart. I got one rear body mount off and seen its pretty rusted enough for it to sink in. How would you fix something like that. Same with the core support mounts. I have pics of those. For the other rear mount i cant get that one out it seems its rusted down inside also. And for the front cab mounts how do you even get those out.
http://www.f150forum.com/attachments...4139551280.jpg
Rear mount that wont come out
http://www.f150forum.com/attachments...3467730222.jpg
Front cab mount
http://www.f150forum.com/attachments...-539736202.jpg
Rusty core support mount
http://www.f150forum.com/attachments...-335947475.jpg
Rusty rear cab mount
Old 08-27-2013, 10:39 AM
Big_Red_Brute's Avatar
Big_Red_Brute
Big_Red_Brute is offline
Body mounts are a b***h to get off. I used a sawzall on mine an burnt through several blades but finally got them off. A cutting torch would work too, just be careful as the rubber is flamable. Bronco Graveyard sells these things called "frame savers" that you can weld to your frame to create a new mount point, but some of yours are so rusty I don't know if they'll work. The radiator supports are an easy fix as you can buy them new and just replace the old ones.
Old 08-29-2013, 07:37 PM
fordka's Avatar
fordka
fordka is offline
ya i figured i would cut some circles out with the plasma cutter and weld them over the rot holes but i dont know what the original size is. where is a god place to get a whole new body mount kit with all the bushings and hardwear.
Old 08-29-2013, 08:19 PM
Big_Red_Brute
I bought mine from Bronco Graveyard. LMC has them too I think. But I would recomend using polyurethane bushings instead of rubber.
Old 08-29-2013, 08:45 PM
Toplait's Avatar
Toplait
Toplait is offline
I bought a set of bushings for 1992 f150. I only ended up replacing the front 2...After doing some research. For mine they are pressed in and I have to use the factory bolt and fabricate a cup with a hole in the middle strong enough to withstand not bending in the center to pull apart the bushing....Well that's what the instructions said after I found them in the bottom of the box after I gave up on completing the task.
bulldogcountry1
08-22-2017 10:40 PM
DougJ_1997PSD
06-18-2015 08:11 PM
gbroehl1
Paint & Bodywork
11-03-2006 04:19 PM
fordtime
08-06-2004 10:39 AM
NoPushrods
Paint & Bodywork
10-08-2001 06:55 PM
Quick Reply: 87 f150 body mounts
