CCT ??
CCT ??
When I try to do the CCT my scantool starts the test, sets a timer, then a few seconds later says I have a P0470 EBP code and is finished. Do I have to fix the EBPS to run the CCT?
My scantool will not clear my codes, either. Says command denied. I am using the TechScan 7000.
Thanks, Sherri
Thanks, Sherri
You need to have your oil temp up to spec and also I believe you need to clear codes prior to doing it. You could also disconnect your battery cables and let it set a while and that would about do the same thing. The KAM or Keep Alive Memory error code may cause an issue for you when you do this though.
Is your EBPV disconnected?
GreaseGun Joe
05-30-2021 08:01 AM
Dr. Driveway
07-14-2014 01:13 PM
TexasGuy001
01-25-2008 04:35 AM
