2007 F150 power steering issues - Ford Truck Enthusiasts Forums
Old 08-24-2013, 01:58 AM
pro2 pro2 is offline
pro2 is starting off with a positive reputation.
I have a 2007 F150 4x4, with 5.4 V8.... 109K miles.
Just recently, my power steering has become intermittently stiff, as if there the power steering pump is failing. Fluid levels are fine, and clean. The stiffness is not consistent through the turn, kinda' "on" and "off," if that makes any sense.
I would appreciate any insight, as I need to make sure I have a grasp on what is going on... I live in a new area, and seeking out a mechanic (in case I cannot fix the problem myself... anything post late 1990s nukes my mechanic abilities), and have cautious of being taken for a ride.
Cheers!
Old 08-24-2013, 09:35 AM
Norman Pyne's Avatar
Norman Pyne Norman Pyne is offline
Norman Pyne is starting off with a positive reputation.
Check the joints on the steering shaft,the one the steering rack end is the most likely one,common problem with these trucks,ford tech told me this. Cost of the shaft here in Canada is around 400.00 from ford, Napa is around the same thing. Joints are not serviceable you have to replace the shaft. Good luck,hope this helps.
Old 08-25-2013, 04:09 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
Have you inspected your drive belt and the PS pump pulley? If the pulley is loose on the center bushing, you'll have to replace it and it requires a special puller. This is probably not your problem - just offering a thought because I just had to replace the pulley on mine.
Stiff steering green_95 1994.5 - 1997 7.3L Power Stroke Diesel 3 08-05-2016 01:18 AM
72 f 100 power steering J C Hope 1967 - 1972 F-100 & Larger F-Series Trucks 2 04-14-2016 05:43 AM
2007 Navigator loss of power steering at time thepros 2007 - 2014 Expedition & Navigator 0 10-06-2015 08:30 PM
6" pro comp lift to stiff MDSLIGHT 1999 to 2016 Super Duty 29 05-26-2014 08:33 PM
Power steering stiff plum716 2004 - 2008 F150 12 03-08-2012 12:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
