Excursion's with 20" OEM wheels - Ford Truck Enthusiasts Forums
Old 08-23-2013, 01:59 PM
DavenTn's Avatar
DavenTn DavenTn is offline
DavenTn has a very good reputation on FTE.DavenTn has a very good reputation on FTE.DavenTn has a very good reputation on FTE.DavenTn has a very good reputation on FTE.
In an effort to maintain a OEM look I'm considering gettin' F-250 8 spoke wheels. I know I need 2" spacers like these;
Billet Wheel Adapter 8 Lug 170mm to 8 Lug 6.5" Thickness 2 Inch - Pair : Amazon.com : Automotive Billet Wheel Adapter 8 Lug 170mm to 8 Lug 6.5" Thickness 2 Inch - Pair : Amazon.com : Automotive
My question is... do they or will they make 275-65R x 20 tires stick out beyond the fender using the Ford 20" wheels and spacers?
Old 08-23-2013, 02:19 PM
Apocalypse's Avatar
Apocalypse Apocalypse is offline
Apocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputation
Not those spacers... Need hubcentric
http://www.ebay.com/itm/140909841663...84.m1497.l2649
Old 08-23-2013, 02:47 PM
DavenTn's Avatar
Quote:
Originally Posted by Apocalypse View Post
They are... hub and lug centric according to Ezaccessory.
Old 08-23-2013, 03:02 PM
Apocalypse's Avatar
I didn't read it, just looked at the pic lol.
Old 08-23-2013, 04:42 PM
WE3ZS's Avatar
WE3ZS WE3ZS is online now
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
Quote:
Originally Posted by DavenTn View Post
In an effort to maintain a OEM look I'm considering gettin' F-250 8 spoke wheels. I know I need 2" spacers like these; Billet Wheel Adapter 8 Lug 170mm to 8 Lug 6.5" Thickness 2 Inch - Pair : Amazon.com : Automotive
Do some more checking before you buy these. In the description section they list the correct vehicle bolt pattern of 8X170mm but the wheel bolt pattern is listed as 8X165.1mm. The late model Ford 20" rims are the same 8X170mm as our trucks.
Old 08-23-2013, 04:46 PM
Forest's Avatar
Forest Forest is offline
Forest is a splendid one to beholdForest is a splendid one to beholdForest is a splendid one to beholdForest is a splendid one to beholdForest is a splendid one to beholdForest is a splendid one to beholdForest is a splendid one to behold
I think you need to do more research and talk to those that have done this upgrade.
Pros:
1) Will look killer AND OEM.
2) Allows larger wheels and offset is set correctly with 2" spacers.
Cons:
1) Seriously diminishes towing capability as it moves 'sweet spot' in torque/RPM curve.
2) May create a problem handling high axle loads if spacers become loose.
The spacers you show in your post look incorrect to me. I have not done this, but I believe you need 170 mm x 170 mm (same lug diameter) for both. Again, you need to search on this topic. Many have done it with satisfactory results. I just don't think they tow heavy.
Old 08-23-2013, 08:34 PM
recovery7778 recovery7778 is offline
recovery7778 is starting off with a positive reputation.
you need the ones with the lip the ones in your first post are not hub centric
Old 08-23-2013, 10:07 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
The guy that bought some on Amazon said he got the wrong ones in his comment already, also; personally I wouldn't trust them for towing, they already have some bad reviews without towing.
Old 08-23-2013, 10:34 PM
Apocalypse's Avatar
The ones I got from eBay are great, no complaints here.
Hubcentric Bolt ON 25mm Wheel Spacers Ford Pattern 8x170 CB 125 5mm 14x2 0 | eBay
Old 08-24-2013, 05:00 AM
DavenTn's Avatar
Guys... I guess I didn't put the right question forward in the way I should. Let me remove the spacer informaton and ask again.
using 2" hub centric and lug centric spacers ;... will they make 275-65R x 20 tires stick out beyond the fender?
Old 08-24-2013, 07:36 AM
HokieHiVPI's Avatar
HokieHiVPI HokieHiVPI is offline
HokieHiVPI is a splendid one to beholdHokieHiVPI is a splendid one to beholdHokieHiVPI is a splendid one to beholdHokieHiVPI is a splendid one to beholdHokieHiVPI is a splendid one to beholdHokieHiVPI is a splendid one to beholdHokieHiVPI is a splendid one to beholdHokieHiVPI is a splendid one to behold
It's either/or, not and in this case. Either they're hub centric, where the lip on the spacer bears the weight, or they're lug centric, where the new posts on the spacer bear the weight.
You obviously want hub centric (lip) and the tires will not stick out past the fenders with a 2" spacer.
Old 08-24-2013, 08:05 AM
WE3ZS's Avatar
World Famous Mod
I agree with Hokie, stay away from anything thats lug-centric, you want a spacer that is hub-centric so it sits correctly on the truck's hub and the spacer also needs the hub-centric hub ring on it to mate correctly with the OEM rims. 2" spacers with the late model wheels is just right, the tires should sit almost in the stock location under the fenders. The difference in the wheels is just under 2" but the slightly thicker spacer at 2" saves you from having to cut down your stock lug studs (in most cases).
Old 08-24-2013, 09:06 AM
MikeRizz's Avatar
MikeRizz MikeRizz is offline
MikeRizz is gaining momentum as a positive member of FTE.
I have 20" wheels from a 2006 F-350 on my X. I bought it this way. The wheels looks great and do not stick out. My truck has a front end vibration at 55-65 that drives me crazy! I have checked everything in the front end, had wheels balanced, etc.. I believe my truck came with the wrong spacers and I am looking to replace them.
As far as towing and power I did not notice any difference. I tow a 24' enclosed car trailer. The tires ate E rated.
Old 08-24-2013, 12:40 PM
DavenTn's Avatar
Thanks for the info... and the pic's are worth a thousand words.
Just an FYI... Cary's spacers, the ones he sells, are both hub and lug centric.
Hubcentric Wheel Adapters dsmm6 Excursion - King of SUVs 1 11-16-2016 05:38 PM
HUBCENTRIC BOLT-ON 25MM WHEEL SPACERS FORD PATTERN 8X170 CB 125.5MM 14X2.0 Apocalypse Ford Truck Parts for Sale 5 10-29-2014 02:31 PM
superduty wheel adapters recovery7778 Ford Truck Parts for Sale 0 07-25-2014 10:54 PM
Before I buy these wheel spacers... Apocalypse Excursion - King of SUVs 118 07-18-2013 12:49 AM
come on guys i know you guys can answer this in 2 seconds cws10190 1973 - 1979 F-100 & Larger F-Series Trucks 18 09-25-2012 08:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
