Excursion's with 20" OEM wheels
#34
I just spotted a set of these on craigslist.
They ARE NOT mine but its a smoking deal!!!
F250 F350 Factory 20" wheels Polished Shiny(4)
On another I confirmed my 55-65 mph front end shake was indeed caused by the spacers/adapters I have on the truck ( on the truck when I bought it ). i removed them for a test and took it for a ride, smooth as glass. I obviously cannot continue to run these wheels with no spacer. Who make a good one?
#35
Thanks! Never thought of that! Good idea.
#36
Thank you guys!
I am only 20 minutes from there if someone needs me to take a look.
I'm gonna get steel ones 'cause I tow heavy on occasions... but I truly believe for 95% of applications the aluminum 6160 (from billet) are fine as long as they are hub centric and not made in China.
#37
2000 excursion with the factory 20s on 2 inch aluminum hub centric spacers
I have a V10 4wd I just put the factory 20s on it but had to get the aluminum spacers I seen a lot of bad reviews on aluminum but also people said if they’re hub centric it Wouldn’t matter well I put them on torqued everything to spec and immediately after I towed a 35ft bumper pull travel trailer 10k pounds about 6 hours away With no issues. And I also just added the air bag suspension assist for my 30ft. My factory 20s have I think 35s on them so I had to cut a little of the fender well but very minimal.
#38
WERNER1
15
06-03-2019 04:20 PM
