UVCH pig tail wires splice together?
I just bought this truck its a 96 f350 dually, I am new to the diesel. The truck was running fine went to a friends house and then when the truck started it was running really bad. I got the truck home and started reading the forum after a bit of research it looks to be the passenger uvch. The front pass side pigtail is burnt and the two outside wires are spliced together. Kinda wondering if there might have been a problem prior and someone tried to put a band-aid on it. Any thoughts?
Thanks james
Thanks james
on
1 Post
You can buy '99-'02 7.3 Super Duty UVCHs and pigtails. They only have one plug per side and are supposed to be heavier gauge wire I believe. They are cheaper than ours too. You take all the wires from the two pigtails, and wire them to the one SD pigtail. It's not hard to do if you know how to solder wires.
Don't forget the .50 cent mod, https://www.ford-trucks.com/forums/9...ml#post8408158
This is my build thread last winter, its in there someplace, still can't believe this thread ran that long!! Oh, that's right, I'm a slow worker, LOL https://www.ford-trucks.com/forums/1...-mod-list.html
Edit: try page 61.
Edit: try page 61.
Make sure you do the 50 cent mod, just in case. Some never have problems with the connector, but some do. For 50 cents, its worth making sure it doesn't happen to you.
The only heavier wires are the glow plug wires, but that's the ones we want heavier anyway. I put them on the same time Glenn did. I liked the idea of heavier glow plug wires, plus being about 100 bucks cheaper for it all.
grelsner96
09-06-2007 08:25 AM
