Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
engine type
Old 08-22-2013, 11:32 PM
C-700's Avatar
C-700
C-700 is offline
engine type
what is a JB5-1107D ford engine type?
Old 08-23-2013, 01:45 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,591 Likes on 1,296 Posts
Year, configuration, any other info? That number brings up nothing on a search. Where did you get that number?
Old 08-23-2013, 05:27 PM
C-700's Avatar
C-700
C-700 is offline
engine type
This is an EAM motor, guessing 1954. It has a Ford plate on the front of the block that calls it that type and a serial number, not a rebuild plate. I am sure this is a 317 but what is the type telling me. Does not seem to have ever been apart. Had a huge airplane prop on it.
Old 08-23-2013, 06:41 PM
85e150's Avatar
85e150
Lincoln y-block, mostly a paperweight these days due to the impossible parts situation.
Home
Old 08-23-2013, 08:08 PM
C-700's Avatar
C-700
C-700 is offline
paper weight
Acually I am running one of these. I am just interested in the type on the plate on the engine. This engine probably has less then 120 hours on it. The pressure plate has never been depressed. I am talking almost new and very dirty. I was just looking for an answer, did not figure anyone on the sight would have any idea, but it is worth a try. Anyone needing parts for one of these 317 truck engines I know where there is some stock stuff. If any one figures this out please let me know. Thanks
Old 08-24-2013, 10:19 PM
85e150's Avatar
85e150
It had a prop on it--like a big blower for movie shot wind storms or an airboat?
Old 08-27-2013, 10:51 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Lincoln derived Y blocks installed in 1952 C & F7/8, 1953/63 C & F700/950:
1952/55: 279 or 317 / 1956/63: 302 or 332.
Old 09-02-2013, 11:34 AM
C-700's Avatar
C-700
C-700 is offline
317
JB seams to designate 317 and 5 for 1955. I was wondering about differences between the truck 317 and this industrial engine. Any thought on that?
Old 09-25-2013, 05:15 PM
pilot31's Avatar
pilot31
pilot31 is offline
Originally Posted by 85e150six4mtod
Lincoln y-block, mostly a paperweight these days due to the impossible parts situation. Home
I disagree with that assessment.
While not as cheap to rebuild as a small block chevy, you can get most all the parts you might need at Napa or if wanted evil bay. Gasket kit cost me $100, if needed I could have bought all new internals, rings pistons bearings etc. I even bought a new oil pump, to match the drive on my aftermarket distributor. I will say though that "speed" equipment is hard to come by. But a good running Lincoln y block doesn't need much. Get a better cam, carb, later year four barrel carb, get rid of the oem distributor, (a ford y block dizzy will work) and your pretty much good to go with loads of torque...
PIGGYONAHOG
07-08-2017 01:07 PM
Gregruk
01-08-2012 11:29 AM
Woodsman_30350
18
11-25-2007 09:12 AM
truckzilla
01-25-2002 06:32 PM
Quick Reply: engine type
