My new hydra came in today and was waiting for me when I got home. Figured I'd get it programmed and installed, but there are no instructions and I can't seem to be able to get hydra flash to recognize when I plug up the chip.
I emailed Php and I'm sure they will get back to me in the morning, but I just wanted to ask and see if I was doing something stupid. Am I supposed to wait for an activation code?
Are you using custom tunes, or just what comes from PHP? If not custom, you shouldn't need an activation code. If you do need a code, be aware they are one time use. If you program the chip the first time on your desktop, then want to use a laptop later with the chip in the vehicle, you'll need another code.
No, stock tunes. Nothing custom. I guess since you say I don't really need an activation code for stock calibrations, then my issue is the chip isn't being recognized by my computer. Maybe I'll try a different cable.
Sorry to burst your bubble but you are setting yourself for disappointment if you think PHP will get back to you right away or at all.
I'm hoping the issue is with my cheap gateway which I was told was worth its weight in cow spit. It simply won't recognize that there's anything plugged in, except it would charge the phone.
Jeff, IIRC, there are drivers on the USB key that have to be loaded for the chip to be seen. Did you install those? You can download them from PHP's site, as well.
