Y-Block Push Rods - Ford Truck Enthusiasts Forums
Y-Block Push Rods
Old 08-22-2013, 10:59 AM
captradiator captradiator is offline
captradiator is starting off with a positive reputation.
Y-Block Push Rods
FTE Family,
So, I bent the front push rod on the passenger side of the '57 Mercury 292 that is replacing the 272 from my F-350 wrecker. I figured, I will just get one from the old engine. However, the 292 one is a good bit thicker than the 272's. After searching several parts sites, I have come up with Melling part number MPR-73.
By the way, I bent the push rod by using a bolt that was too long when we put the 292 on the cherry picker to install it.
Thanks in advance,
Old 08-22-2013, 04:22 PM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
There are two different lengths of pushrods as well.
To install the passenger car engine, you will also have to use the truck bellhousing, swap the timing cover and mounting brackets, thermostat housing, oil pan, and exhaust manifolds. If the 272 is older, use the distributor and intake / carb for the '57 car unless you need it to look correct for some reason.
Old 08-23-2013, 10:39 AM
Charlie,
Thanks for your response. The replacement should be here today.
Update on my 60 Fridge Textile302 1957 - 1960 F100 & Larger F-Series Trucks 12 05-13-2016 09:41 AM
292 out of a 64 galaxy newguy399 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 13 03-15-2015 08:16 PM
water pump repair (y-block) Stephen67 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 06-12-2014 03:54 PM
272 vs 292 ireding Large Truck 1 04-23-2013 12:35 AM
rear main leaks!! mtford Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 9 11-17-2008 08:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
