**Update** Neutral safety switch didn't fix the problem
Am having an issue starting my truck where it almost always starts when the truck is only in neutral, not in Park. I was told that that is a common issue when the neutral safety switch goes bad. So I replaced it this morning. Go to start the truck in Park, nothing. Drop it to neutral, starts right up. Shift through the gears, and everything shifts fine. Restart the truck and it starts up in Park. I shut it off and restart it, nothing. Drop it to neutral, starts right up.
I tried a couple more times, with the same result. I made sure that the neutral lines were perfectly aligned when I installed the new switch. Any suggestions as to what the issue might be? Thanks.
Received 3,090 Likes
on
Yeah, I would say there is some play in the shifter. Sometimes the indicator in the cluster doesn't line up perfectly, and I can adjust that by pushing gently up or down on the shifter, so I guess that would qualify as play.
I double checked the connection on the sensor and it wasn't loose. Maybe also inspect the wiring under the truck for any shorts if the torx bolts don't solve the problem? I'd like to troubleshoot as much as possible before spending anymore money on replacement parts.
Took the cover off my steering column, and tightened those Torx bolts, still some play and no solution. I haven't had time to check the wiring under the truck leading to the neutral safety switch yet, but I noticed some stuff about the wiring while the fuse panel was off.
These wires were exposed for some reason. Not sure what they're for, but I covered them with electrical tape.
These ones were just plain cut. one had a little tape pinched over the end. Not sure what those are for.
But if the wiring under the truck tests out alright, would the next step be to replace the shift tube? if so, what do those run?
on
Well there are several other things you might check that are associated with this first. The two torx head bolts on the armature that the cable connects to. If you find them loose it may be as simple a fix as tightening them. Be careful like the video says these are threaded into aluminum. The mechanic in the video says he just goes by "feel". I don't trust my "feel". The Ford factory service manual for my 2001 F250 says (12 lb/ft) on these bolts, I'd assume it is the same for your 2000. I think you said you checked them already, but this is the easiest fix. Now, it could be the cable itself. When I was trying to figure my issue out I had a mechanic tell me that the cable can "stretch" and that his was doing the same thing and he just replaced his cable and it fixed it for him. It could possibly need replacement, but truthfully, I'm not sure about the cable stretching. But I thought I'd share all of what I've been told. If you have a lot of slop in your shifter, I'd just replace the shift tube assembly. Note in the video the mechanic replaced the shifter, but that only because the OD switch was also bad. You should not have to replace this unless your is a problem. Ed the Parts Guy (Horizon Ford) has what you'll need at great prices heres a link your parts 2000 FORD F-250 SUPER DUTY Parts - WWW.HORIZONPARTSGUY.COM
Best of luck
Best of luck
The bolts that need to be tightened are not under the steering column cover. The bolts you need are near the floor. To find them lay on your back looking up at the column.
