08 Expedition transmission "jump" - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 08-22-2013, 05:04 AM
Nickybear Nickybear is offline
Nickybear is starting off with a positive reputation.
I have an 08 Expedition Limited 4wd. Anytime I accelerate from a stop the tranny jumps into first and bounces forward. And the opposite as I'm approaching a stop, right before I reach a complete stop it jumps forward a little bit. I say a little bit to stress that its not pulling the truck forward as to be unsafe, but its a very hard bump. Other than that it runs and shifts fine. It seems to be getting worse.
I just had the dealerships $650 "tune up" done, not sure what all that entailed but it ran much better after having that service done. It did this transmission jump thing very slightly before I had the tune up. It's bad enough now that passengers notice and ask what it is.
I'm supposed to leave from Dallas TX driving to Northern Nevada for burning man. About a 30 hour drive each way. And much of it is hundreds of miles of desert with nothing around for a few hundred miles really don't wanna break down out there.
Also my gas mileage sucks. I get no better than 9 ever, used to get 12-13 hwy.
Any thoughts? There are no codes or warning lights up.
-Nick
Old 08-24-2013, 12:49 PM
sandrat's Avatar
sandrat sandrat is offline
sandrat is gaining momentum as a positive member of FTE.
Can't remember for sure, but I think there is a reprogram available for the PCM to cure this problem.
Old 08-24-2013, 06:18 PM
montecarlo31 montecarlo31 is offline
montecarlo31 is starting off with a positive reputation.
If I am not mistaken 08, maybe it was 07, had a TSB for removal of the trans and installation of a clutch pack to help prevent the rough shifting.
Old 08-24-2013, 06:56 PM
Hmm
I've read a few other posts. It only happens after 15-20 minutes of driving. Which kinda leads me to think its not a programming issue. Guess ill just have to take it in :-/
Old 08-24-2013, 08:22 PM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
Quote:
Montecarlo31,
The clutch pack one was for the downshift "sqauwk" noise. TSB 09-6-1
Nickybear,
The one for the "bump stop" is TSB 08-22-7 this is a simple reflash of the TCM. Dealership will probably charge you whatever the 1 hr rate is.
Matt
Silver State Run - 2016 (March 18-20) M3dragon Nevada Chapter 2 03-30-2016 01:39 PM
Introducing myself: Ditzy but methodical blonde in Reno, NV area tanya_charbury New Member Introductions 21 09-17-2015 07:39 AM
'77 "Green Truck" Slow Build '77 Dent 1973 - 1979 F-100 & Larger F-Series Trucks 25 09-23-2014 10:01 AM
5star vs superchips, superchip wins? rayofsi Computer Chips & Tuners 12 01-21-2014 10:55 PM
1976 F250 lack of Power Nevada Dan 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-03-2012 08:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
