1956 - Chopped, Sectioned, with a S^3 engine (Supercharged-Straight-Six)
#46
#48
The 56 cab is a very difficult chop with the wrap around windshield. I like what they did with Foose's 56. They left the roof and glass frames alone and wedge sectioned the cab at the beltline, 0 at the back to 1-1/2" at the front across the cowl just below the wipers and across the dash thru the flat part.
The 56 windshield is already narrow with the overhang.
As tinman says if you are going to chop the top, have the glass cut first and adjust the windshield opening to fit the cut down glass during the chop. There are a lot of windshieldless chopped 56 cabs up for sale cheap that were attempted the other way around, especially when the roof wasn't stretched in the process. buy a couple windshields the likelyhood of successfully cutting the glass without breaking it the first attempt is slim, even when done by an experienced glass man.
I once saw a chop done on a 56 where they cut a slot in the top of the windshield frame similar to the top of the door frame and let the uncut glass slide up into the roof overhang. There is enough room for almost 2" of glass up there.
#50
#51
Received 4,130 Likes
on
If you chop a top and finally get the glass to fit you need to remember what it cost in the first place when you get that stone that comes up and smacks you when you're liesurely driving down the highway and if your insurance will cover anything other than a stock windshield. I think the 56 looks just fine the way it was designed.
#52
When I view between the before and "after" photos in your post (#47) I see that none of the glass at all is impacted by your chop. It appears that all the work is done to the cowl below the windshield, the tops of the doors the hood and even the bedsides. Is this just a photoshop thing? It seems like a lot of work for the effect.
#54
#60
