6.2 1st oil change - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
6.2 1st oil change
Old 08-21-2013, 07:15 PM
straight axle straight axle is offline
straight axle is starting off with a positive reputation.
6.2 1st oil change
Ok to change my oil for the 1st time @ 3000 miles?
Or is there an additive that is in there from ford that helps with break in and needs to be run till 5000 ish?
Thanks
Old 08-21-2013, 07:22 PM
scraprat's Avatar
scraprat scraprat is online now
scraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud of
I personally change at 3000 with a new engine then 5000 miles after that but that's just my preference. I think the manual says 7500.
Old 08-21-2013, 08:03 PM
ATP Pilot's Avatar
ATP Pilot ATP Pilot is online now
ATP Pilot is gaining momentum as a positive member of FTE.
Thanks
no break in oil, change it.
Old 08-21-2013, 09:14 PM
Thanks guys.
That's what I was thinking but wanted a 2nd opinion.
Old 08-21-2013, 09:20 PM
saratoga2011's Avatar
saratoga2011 saratoga2011 is offline
saratoga2011 is starting off with a positive reputation.
I did my first one at 2500 with MC 5W20. Just did the 2nd at 7500 last weekend with M-1 5W20 EP.
Change it early if you want, no harm done. I'm going to go the full 7500 from now on.
Best oil? Curt's05 1968-2013 Full Size Vans 28 07-23-2014 09:23 AM
Best oil? Curt's05 Excursion - King of SUVs 27 07-22-2014 06:47 AM
Oil smells sour RowDona Oil & Lubrication 2 02-09-2014 03:38 PM
Magnetic drain plug clintbonnie 1999 - 2003 7.3L Power Stroke Diesel 5 01-04-2006 09:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
