Rolling Error codes, 2002 XLT - Ford Truck Enthusiasts Forums
Old 08-21-2013, 06:11 PM
laker82 laker82 is offline
laker82 is starting off with a positive reputation.
Engine would not start with high voltage at Ox sensor and high voltage DPFE erro codes. Cleared codes engine started and ran 2 days. Would not start, no error codes returned.
Tapped on ERG and drove it home. Started up again. Traded DPFE with other 02 explorer and both ran fine. Sat overnight, theft alarm went off at 7:15 am, engine would not start.
Changed ERG as I had cleaned it 4 years ago, little sticky but working. Started drove out of garage, died. Returning high voltae DPFE. Starts no power. wigled wires around DPFE and throttle. Cleared code, returning high voltage engine coolant.
With DPFE unplugged and key on engine off DPFE 2 leads have 5 and 6 volts.
I'm thinking short in harness. anyone have a likely spot. Where do oxy ,dpfe alarm and engine coolant wires share space?
Not going to be fun.
Old 08-22-2013, 05:01 PM
Update
Started this morning 4 times. Did not trust it, this afternoon without touching it it will not run.
Traced harness back to firewall and removed. Continuity between grey/red brn/wht wires to DPFE. bypassed harness to fix those shorts. Will not run, on to find the next problem. not surprised, clearing error codes should not have made it run.
PCM or another short?
Old 08-22-2013, 06:58 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Are we supposed to guess what you're working on?
Old 08-22-2013, 08:17 PM
Thank you, that info would be helpful. 02 xlt v6.
Started, ran 3 minutes, died. Now codes PO122, PO118, P1120. Got some harness work to do.
Old 08-27-2013, 02:36 PM
Tested circuits just outside PCM by cutting wires. No backfeeding from shorts that way.
PCM is sending 12 volts to temp sensor instead of 5 volts. Also sending out 6 volts in what should be a variable return signal from DPFE.
dealer cost for PCM with flash about $1k. Ordered junk yard $50 plus shipping.
Started a PCM thread to check out difference in rev to PCM #.
Old 08-28-2013, 07:44 AM
Did you verify the PCM's power ground circuit and the signal ground circuit before reaching that conclusion?
Old 08-28-2013, 08:44 AM
No, I really did not do an in depth check. Did have the same voltage with harness ground and direct to battery ground. I will do some more checking before using the Salvaqge PCM. Thanks for imput.
overheating problems irydasteelhorse 1999 to 2016 Super Duty 11 08-12-2015 07:05 AM
How to test your DPFE sensor. Reuel Modular V8 (4.6L, 5.4L) 47 06-24-2015 10:37 PM
NEW to the forums - Need help with 1999 ford f150 4.6 triton v8 jjsfamily Modular V8 (4.6L, 5.4L) 3 07-02-2014 01:13 PM
1999 E250 Rough Idle & Loss of Power MartinTravels 1968-2013 Full Size Vans 3 05-31-2014 07:52 AM
1995 California 5.8 PCM DPFE SteelHorse4x4 1987 - 1996 F150 & Larger F-Series Trucks 6 05-30-2014 02:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
