Rear axle oil seal replacement - Ford Truck Enthusiasts Forums
Old 08-21-2013, 01:31 PM
Tony65 Tony65 is offline
Tony65 is starting off with a positive reputation.
I was in the process of re- doing the brakes on my 68, F-100, 360. I had an interesting problem in the front. When you hit the brakes the right would lock up and not release. You had to relieve the pressure at the wheel cylender to get tit to unlock. After much crawling loosening and cursing, I found it was the brake hose that was clogged with 45 years of gunk. That was enough, the steel lines are good but everything else is being replaced or rebuilt.
I got around to the rear and when I pulled the right drum everything was soaked with oil. The wheel cylinder is tight, no leaks, its definately the axle seal. I searched it up on this site, seems pretty simple, rotate the flange to loosen the bolte, pull the axle replace the seal and the 2 gaskets.
Is there anything else that I should know before I get started on this?
Thanks, Tony
Old 08-21-2013, 01:48 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
I'd replace both sides since they are likely the same age.
Apply a very thin film of RTV around the seal before installing.
Lube the seal prior to inserting the axle.
Use a torque wrench.
Old 08-21-2013, 06:52 PM
CougarJohn CougarJohn is offline
CougarJohn has a good reputation on FTE.CougarJohn has a good reputation on FTE.CougarJohn has a good reputation on FTE.
The fronts are easy. As above.
The rears, not so.
You have leaking axle seals. You will need a slide hammer puller to remove the axles. Rental shop. After that, you will need the puller with a hook to pull out the axle seals. You must be very careful in replacing the seals as they can get warped and bent on the way in. You will be back in again if they are not driven in properly. There is a driver tool to do this. And, if the vehicle is original, it would be a good idea to replace the axle bearings. And check the lube level in the differential as you have a leak.
If I am wrong the guys will correct me.
If you are not familiar with the rear-end problem I would advise you to go to a shop if it a once-in-a-lifetime repair.
Semper Fi
Old 08-21-2013, 08:31 PM
JEFFFAFA's Avatar
JEFFFAFA JEFFFAFA is offline
JEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant future
2X CougarJohn with one addition. You can use the brake drum as the axle slide hammer. Just put the drum back on backwards. Put the lug nuts on backwards about 6 threads or so. Now slide the drum back and forth just as you would a slide hammer.
Old 08-21-2013, 08:46 PM
f100today's Avatar
f100today f100today is offline
f100today is gaining momentum as a positive member of FTE.f100today is gaining momentum as a positive member of FTE.
Every axle I have removed from a 9 inch ford rear end came right out without any type of puller?
Am I lucky?
Old 08-21-2013, 09:19 PM
GLR's Avatar
GLR GLR is offline
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
I've just popped the axle seals out using the end of the axle.
When I worked in the dealership, we would replace the axle bearing also. Figuring if the seal leaked enough to soak through the bearing, the grease in the sealed bearing would be "washed" out.
Old 08-21-2013, 10:48 PM
orich's Avatar
orich orich is online now
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
I'd also replace the rear wheel cylinders. Looking good from the outside doesn't mean it's not full of crap. And will end up leaking when new lining is installed as it pushes the cups into the crap and will start leaking. Hell new ones at auto zone are only $10 bucks each. I would not waste any time trying to rebuilding them as they mostly are all eaten up inside from moisture settling in bore that won't hone out..Plus the rear rubber flex brake hose as they crack over the yrs..like the fronts do...my 2cents..orich
Old 08-28-2013, 03:49 PM
Thanks for the good advice. I'm still playing with the brakes. I rebuilt the fronts and was trying to bleed them but I couldn't free one of the bleeders, I finally got it out but it was trash. So I tried to find another, No luck, no parts house had one in stock, its not a 3/8, its metric, this was about the time when our government decided to go metric and some vehicles came out with metric threads on some parts. A couple said they could order one for about 6 bucks and a rebuilt wheel cylinder is 12. Long story, short, I went back in and installed rebuilts with sae parts. Now the rear end, I'm not sure the seals are shot, the vent hose was plugged, so I filled it up with gear oil and am watching it, If it leaks I'll change both seals
Old 08-28-2013, 04:08 PM
orich's Avatar
Oh yeah the bleeders, I just went through the same thing on my rear cylinders when, I bought new cyls. from auto zone. The new Bleeder were metric wrench nut size only and cylinder threads were standard ase.
Not metric so use my old ones.. worked for me...orich
How to rear hub seals and parking brake shoes camodown 1999 - 2003 7.3L Power Stroke Diesel 123 12-28-2015 10:42 PM
Problem finding the correct transmission output seal Tony. 1987 - 1996 F150 & Larger F-Series Trucks 7 07-07-2015 08:59 PM
292 Y-Block has never really run right wfon 1961 - 1966 F-100 & Larger F-Series Trucks 10 10-08-2014 08:45 PM
Can a 460 oil pan be removed with engine in? abranz 1987 - 1996 F150 & Larger F-Series Trucks 1 02-05-2007 04:06 PM
Huck brakes tltodd 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 11-02-2005 10:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
