heads cam and carb swap questions - Ford Truck Enthusiasts Forums
Old 08-20-2013, 09:49 PM
jrp79 jrp79 is offline
jrp79 is starting off with a positive reputation.
Got a 95 f150 302.found out its all stock except for the shorty headers and strait pipes.
The trans has already been swapped with a c6.
Would gt40 or gt40p heads be a good improvement.whats the difference in those heads.
Also would a x303 cam be a good choice with those heads and i plan on swapping to a carb set up with a weiand stelth and edelbrock 600 carb.
I guess is what im asking is what would give me good power and have the lopey sound.
I built a 85 gt 302 before with 9.1 pistons and trick flow s1 cam on sd system and ran like crap.converted it to carb and what a difference it made.
My truck isnt running good due to bad maf and who ever knows what else is bad.
Old 08-20-2013, 10:10 PM
nflfreak43's Avatar
nflfreak43 nflfreak43 is offline
nflfreak43 has a good reputation on FTE.nflfreak43 has a good reputation on FTE.
Why if you have MAF would you go backwards to a carb?!? Thats just a dumb idea..
Old 08-20-2013, 10:21 PM
Tunning wise.wouldnt have to worry about tunning the computer for future upgrades
Old 08-20-2013, 10:42 PM
Evan_P's Avatar
Evan_P Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
Buy a Tweecer or a Moates and you can tune it easily and keep the efficiency. I have NO idea why people think a carb is better...
Old 08-21-2013, 01:30 AM
garthneddy's Avatar
garthneddy garthneddy is offline
garthneddy is gaining momentum as a positive member of FTE.
For the price of a nice intake and carburetor setup you could purchase a new MAF meter, have your truck tuned for the heads and cam your going to install and have some change left over. Keep the EFI and ditch the alphabet cam.
Old 08-21-2013, 08:04 AM
Are those tunners?do u happen to have a link where i can check them out?alot of people say the letter cams are out dated.what would u sugest for a cam.
Old 08-21-2013, 08:28 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Alphabet cams are a lousy choice for a truck motor.. besides being out of date, a truck weighs a lot more than a Mustang so you can't use the same parts or it'll be a slug.
Use the Comp 35-320-8 with those heads and look here for the tuner and Binary Editor software..
'QuarterHorse' for Fords [QH1] - $249.00 : Moates.Net
Shop
help gutless 302 85transamjunkie Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 10-06-2014 11:14 AM
88 f150 motor swap help please? 85transamjunkie Engine Swaps 0 10-05-2014 05:44 PM
GT40P Heads broketruckjohn 1987 - 1996 F150 & Larger F-Series Trucks 3 10-20-2013 09:16 PM
Should I upgrade to a four barrel intake manifold jsutton Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 17 10-14-2013 11:20 AM
another 302 upgrade information needed GT40 heads jaye Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 08-08-2011 07:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
