"Police Dark Mode" to stop the parking light display - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-22-2013, 12:04 PM
Byram's Avatar
Byram Byram is offline
Byram has a good reputation on FTE.Byram has a good reputation on FTE.
Me also....
Many times we drop off hunters at there spots and go park on a crossroad before daylight... I'll watch wildlife for a while - but occasionally we need to open the door - to kill a hog or just get something out of the cooler... Boom - it lights up like a X-mas tree and any animals take off....
On my 2011 I tried putting a toggle on the drivers door to see if I could make it work... It kind of worked - but had other issues also...
Anybody who gets the answer post up! -
Old 08-22-2013, 12:47 PM
djm1204's Avatar
djm1204 djm1204 is offline
djm1204 has a very good reputation on FTE.djm1204 has a very good reputation on FTE.djm1204 has a very good reputation on FTE.djm1204 has a very good reputation on FTE.
The "unitrol" switch box was a progressive type thing, first notch would disable interior courtesy lights, second all interior lights including dash, as the operator moved the switch tot he right, each additional "click" or stop would include all previous features and add additional ones.
It was not an all or nothing situation. I do not know if they still make them, I did just look on e-bay and saw several of the Unitrol control heads.
Old 08-22-2013, 01:59 PM
CarlT100's Avatar
CarlT100 CarlT100 is offline
CarlT100 has much to be proud ofCarlT100 has much to be proud ofCarlT100 has much to be proud ofCarlT100 has much to be proud ofCarlT100 has much to be proud ofCarlT100 has much to be proud ofCarlT100 has much to be proud ofCarlT100 has much to be proud ofCarlT100 has much to be proud ofCarlT100 has much to be proud of
I could not find that particular control on Unitrol's website. They make a lot of controls; but I could not find this one.
Old 08-22-2013, 02:21 PM
DaveNTx's Avatar
DaveNTx DaveNTx is offline
DaveNTx is starting off with a positive reputation.
That sounds like the type of thing I could use. Is this Unitrol company the same as Federal Signal Unitrol? That's the only web site I can find with the Unitrol name that seems to have anything to do with vehicle electronicss.
Old 03-09-2014, 09:05 PM
rbtom rbtom is offline
rbtom is starting off with a positive reputation.
Is there anything in the BCM to enable or disable? I have a 2014 f350 diesel lariat. Thanks! !
Old 03-09-2014, 11:01 PM
SD Dually's Avatar
SD Dually SD Dually is offline
SD Dually is starting off with a positive reputation.
I personally like all the running lights coming on when the door is opened, though I'm glad my headlights don't come on.
I do feel that the light display should be an option to disable for the people who don't like it.
I think the dome/cargo light are on a different channel though. Sometimes when I open my door and leave it open the running lights shut down after a short period of time (just as they do when the door is shut) but the dome & cargo light stay on longer, but when I close the door the running lights and cargo & dome lights all shut off at the same time, again after a short period of time.
I wish the cargo light would be on a separate switch from the dome light, I would like to turn the cargo light on when backing under my slide-in at night.
SD Dually
Old 03-09-2014, 11:22 PM
MauiGrown MauiGrown is offline
MauiGrown is starting off with a positive reputation.
Quote:
Originally Posted by duckstab View Post
I have a F250 that was a Texas DHS truck in a previous life. It must be running in the police dark mode you mention. There is no illumination, anywhere, when I open the doors to enter/exit the vehicle. I have to manually flip the switches on the ceiling of the cab to get any interior light. I've only had the truck for a few weeks, so I am yet undecided if I like that feature. It also came with rubber in place of carpeting, which I definitely like.
i also just bought a 2005 f250 xl that was a state vehicle and i think it has dark mode on too. i have the same problems as above but i don't have door, seat belt, or key chime either. and the radio must be turned on manually. i want the opposite and turn it off. or could this be a whole other problem? dimmer switch still works and lights come on when truck is turned off and door opens but that is the only time
Old 06-19-2014, 09:15 AM
BBT Mech BBT Mech is offline
BBT Mech is starting off with a positive reputation.
I have turned several of these police modes on in the last few days for CBP. It is a toggle in the body control module that can be enabled/disabled but you need Ford IDS software to do this. Make nice with a Ford technician and let him know to go to module programming/programming options and he will see police options, dark car is one option that can be enabled.
Old 06-19-2014, 09:18 AM
Djfargo Djfargo is offline
Djfargo is starting off with a positive reputation.
Dark mode...
Quote:
Originally Posted by DaveNTx View Post
I've been prowling the internet, looking for some information about how to turn off the parking light + cargo light display when the doors are opened and found something called "Police Dark Mode".
Apparently, it is a programming option within the diagnostic application used by the dealership. Once it is turned on, the dazzling light display that occurs when you open the door will stop, however; it's not clear if this shuts down the interior lights also.
I don't mind the interior lights coming on when the door opens but, the exterior light display doesn't make much sense.
Has anyone here had the "Police Dark Mode" turn on for their Super Duty truck?
I had it turned on @ the dealership in my 2011 F250, just a simple option in the menus... took all of 15 seconds.
Old 08-24-2014, 01:48 AM
markII markII is offline
markII is starting off with a positive reputation.
I will try and get Ford tech to do the dark mode. Until then, I pulled fuse 12 under the right passenger foot area to stop the dome light and bed light from coming on every time the door opens. I still have the running lights that come on, it drives me absolutely crazy that this isn't on a simple switch.
Old 08-24-2014, 02:27 AM
djm1204's Avatar
Quote:
Just curious - what would some of the other police options be ? anythuing we might want turned on or off ?
Thanks
Dan
Old 08-24-2014, 06:45 AM
Quote:
Just wondering if the fuse is pulled do you completely lose the dome and cargo lights? Also what year is your truck?
Thanks, Tom
  #28
Old 11-28-2014, 07:23 PM
railroader railroader is offline
railroader is starting off with a positive reputation.
My Ford mechanic friend did it for me while we were talking about the latest Oasis stuff, which I knew very little about. Took maybe a minute. I like it.
Sync 3 display switches to bright white at night if headlights are off troverman 2017 Super Duty 12 01-10-2017 07:47 PM
Front Courtesy door lights and dome lights don't work JJONES7432 Explorer, Sport Trac, Mountaineer & Aviator 6 11-10-2015 03:22 PM
Courtesy Lighting? Ginther 1999 to 2016 Super Duty 0 09-20-2015 07:21 PM
Help with interior lites and Teu anmperature Display oregonwoman53 1997 - 2003 F150 4 12-19-2014 12:14 PM
Piscataway woman killed by hit-and-run driver after trying to rescue hurt dog smotrs General NON-Automotive Conversation 15 06-27-2011 09:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
