Dentside steering column bracket / firewall plates - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
Old 08-20-2013, 09:01 AM
JustBlaze's Avatar
JustBlaze JustBlaze is offline
JustBlaze is starting off with a positive reputation.
Hi Guys,
I'm looking for the plates that go on the firewall that the steering column passes through. I have a 1973 cab with power steering. There is one plate on the cabin side and one on the engine bay side.
Here's a few pics borrowed from 9thPony's build thread for refrence.
Thanks
-Justin
Old 08-23-2013, 08:15 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Will what you need work if it came of a 79 Bronco? I believe they are all pretty much the same under there?
I have a parts bronco that still has all that stuff....
Crew Cab Project - The Long Journey 9thPony 1973 - 1979 F-100 & Larger F-Series Trucks 195 01-15-2017 01:13 PM
Header to leafspring clamp clearance issue 9thPony 1973 - 1979 F-100 & Larger F-Series Trucks 10 03-14-2014 08:22 AM
NP205 Front Output Yoke Question 9thPony 1973 - 1979 F-100 & Larger F-Series Trucks 11 01-17-2014 01:47 AM
Let's see your multi-colored dent! 9thPony 1973 - 1979 F-100 & Larger F-Series Trucks 5 08-01-2013 09:24 AM
Clutch Firewall Re-enforment plate installation IDIDieselJohn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 01-30-2012 02:37 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
