just got a 1996
Agreed.. I've never used a FloPro, but I'd use them over MBRP all day on an OBS.. My old MBRP pipe hit in 3 different places and got a hole rubbed in it.
It took me three attempts to get the clearance I needed to make the MBRP work in my white truck. The red truck had th diamond eye in it already, but I can tell just from looking at it that it was easier to do.
Also, too bad you bought the Tymar intake kit. Almost everyone here will direct you towards the 6637 system from Riffraff. (That reminds me that I never posted any pics of my filter set-up.)
When you change the fuel filter be sure to clean the screen in the little hole at the top of the fuel bowl that goes back to the FPR.
Congrats on what sounds like an awesome truck. I can't wait to see some pictures, AND FOR THE LOVE OF YOUR TRUCK, DO NOT PUT AN EDGE EVOLUTION PROGRAMMER IN IT!!! I cannot stress that enough.
Would love to see pics! Don't worry they did the same to me when I started hanging around here. Hang round here long enough and you will learn much. Your wallet may be a little thinner because of it but what the hey right?
6637 filter is an easy mod with the kit. I had a K+N on mine and it wasn't too much longer it was gone bye bye. Also had a EDGE programmer on it which has also gone byebye. But my truck has alot more miles than yours (Just rolled over 359K) so you should be good for a while yet.
Going with what everyone else is saying, make it reliable first (fluids, coolant, filters etc) then make it yours! Don't be afraid to ask questions, the guys here really know their stuff.
Mine was in for about 40 k before I got the truck. I took it off once and put it back on just to see if it was making a difference. and just recently took it back off again. I haven't noticed any problems. I think you run into problems when you accidentally unplug them before they have finished doing what they are doing. I know still not recommended for our trucks. But I'm glad I was enlightened to what they can do.
#29
I have just left mine where it is since I got it. I haven't even plugged it in to see what setting it is on! I figure it is best to just leave it alone!!! My plan is to pull it off and get a tuner and chip this fall or winter and I am pretty sure the PO didn't mess with it much. The mileage is good, truck runs good, doesn't seem like it is running overly hot or anything (I don't have an EGT gauge though), so I'm just hoping I can pull it off when I am ready and not have any bad effects.
I think my EGT's are actually up slightly with out it on there, I never got much above 1100 with the programer on there so I'm sure your fine.
#30
