I have no luck - Ford Truck Enthusiasts Forums
I have no luck
Old 08-19-2013, 09:56 PM
monte97z's Avatar
monte97z monte97z is offline
monte97z is starting off with a positive reputation.
I have no luck
OK guys I have now seen it all, I was under my rig today trying to figure out my loose steering and I find my cradle is literally splitting. Now about 3 months ago I ran all new brake lines and it was not like this, so this has happened in the last few months. I only drive it like 5000 miles a year so maybe 1000 miles Max in the last few months. She is empty most times and occasionally I haul some equipment to work around the house, get mulch, or lumber things like that no massive weight. I have two questions now. How does one actually split the engine cradle and does anyone make them after market? Junk yards around here don't keep these truck, no one wants them and they r worth more in scrap then in parts. So if a bone yard is my only option what vehicles, (truck, van, ambulance) will the cradle work from. I don't wanna scrap the truck but I'm not sure where ill be able to find the parts. Any ideas guys?
Old 08-19-2013, 10:07 PM
monte97z's Avatar
Closer picture
Old 08-19-2013, 10:08 PM
monte97z's Avatar
There is a lot of grease and oil on it. Its not rotted in any way and has a nice ring to it when hit with a hammer
Old 08-19-2013, 10:36 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is online now
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
Go-go-gadget WELDER!
Old 08-19-2013, 11:00 PM
Chevy_Eater's Avatar
Chevy_Eater Chevy_Eater is offline
Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.
And whilst welding it I bet you could add some braces to it and make it better than new.
Old 08-19-2013, 11:01 PM
And don't feel too bad, if we didn't have bad luck....
....we'd have GOOD luck and life wouldn't crap all over us all the time.
Old 08-19-2013, 11:19 PM
monte97z's Avatar
Lol well I guess bad luck gives me reasons to fix thing lol. And hey. What would life be be if things never went wrong. But honestly I did not think that could be welded back but if its a viable option then that may be what I got to do. Ill down the truck cause there is no way I will drive it like that, and gather some parts up while I pull the engine gonna do oil cooler which is leaking and the head gaskets cause I need those too, driver side weeping a bit. Looks like I got my winter project
Old 08-19-2013, 11:47 PM
Yep, i would not hesitate to weld it. Drill a 1/4" hole or so at the end of the crack and weld away. Like chev said you could grind it flush once welded and fishplate it or something. Depending on your welder and sillz with said welder i would just try welding it and seeing how it holds up myself.
Old 08-20-2013, 12:04 AM
monte97z's Avatar
OK sweet that's not so bad then, I was fearing the next 6 months searching for parts. My welder will never be able to do that, doubt it has the power and my skills are not up to that task. Ill weld exhaust or brackets for thing but nothing structural, don't think I have the skill. But I should be able to get my brother to do it, be a 12 pack job if I pull it lol. Im not letting this truck go out like this lol. Thanks guys
Old 08-20-2013, 01:13 AM
kobaltblue's Avatar
kobaltblue kobaltblue is offline
kobaltblue is gaining momentum as a positive member of FTE.
Damn that's some major structual falure, you have to have something else going on you should clean up that part of the frame and inspect it better.
Old 08-20-2013, 07:23 PM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
I agree with kobaltblue, something caused that, if its not rust, something else went wrong. That looks like right where the TTB bracket is, which can explain the steering issue. Did you hit something hard with the passenger wheel? Maybe a pothole or curb? Just taking some wild guesses.
Old 08-20-2013, 09:17 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Wow that's a new one for sure!
Never seen, or heard of this happening.
Old 08-20-2013, 10:42 PM
airdale94's Avatar
airdale94 airdale94 is offline
airdale94 is starting off with a positive reputation.
That's a fairly common issue I think. I worked for company that had one ton van chasis (handi cap) busses. And several of them were welded in this area. Part of the PM was checking for cracks or checking the welds.
Old 08-20-2013, 11:10 PM
monte97z's Avatar
No that's the weird part I can't remember hitting anything and I'm the only one who drives it, just not something I have ever seen or herd of. I'm thinking, I'm just gonna pull the motor and see where it stands. I'm not looking to open a can of worms but if my brother can weld it back up then that's what ill do. But ill keep my eyes open for a replacement as well. Its just weird to me, that's a pretty good chunk of steel to be peeling open like that. But it looks like this will be my winters project as I'm low on free time and I have a feeling this is gonna take a lot of it. I'm just glad I noticed it before I had the wife and kid in it, I hate to think what would have happen if it failed while I was cruising down the highway
Well, it's almost time. 51 F1 mustangmike6996 1948 - 1956 F1, F100 & Larger F-Series Trucks 355 01-04-2017 07:53 PM
6.0 swap options? ford4v429 6.0L Power Stroke Diesel 13 11-21-2011 05:01 PM
Possible donor truck? Built_Ford_Tough_757 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 08-09-2011 09:28 PM
Engine Cradle for a 400 Fat&Bald 1973 - 1979 F-100 & Larger F-Series Trucks 0 01-22-2011 04:02 PM
XM in a 07 F-150 useing Sirius ant tbear853 2004 - 2008 F150 0 07-09-2010 03:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
