95 f150 302.what mafs can i use.tb and injector question
My mass air sensor is bad and was wondering what mafs i can use or does it have to be from a 95.
What size tb is stock and what size injectors.
My motor has a edrlbrock rolling thunder cam, shorty headers with no cats or mufflers.i want it to run as close to best with out a tune for now.
Was thinking about maybe mustang 19 or 24lb injectors, explorer 65mm tb and if a stang mafs caled for the 19s or 24s would work.
Mafs is bad.i check for 12v at the live and both grounds and was good.the signal wire showed nothing
on
That would be a downgrade.
Signal wire should be at zero unless the engine was running. Are you also getting codes for the MAF?
If you do have to replace the meter then one from a 5.0 or 5.8 truck would be the best.
Is the 5.8 maf the same as the 5.0.the 5.8 isnt bigger in dia. And its calibrated for the same as the 5.0 maf?
on
The dyno results I have seen contradict that, the Explorer intake produces more low to midrange torque than all the others including the Holley which interestingly is heavily based on the 5.0 truck intake.
The explorer intake is a good upgrade for a car or a lower reving engine. But there are plenty of better choices if you're willing to spend the money.
covshark
24
02-13-2013 03:39 PM
Jimn8or
12-10-2008 11:47 PM
