Ford fan/hub assembly ID?
Old 08-19-2013, 05:45 PM
Montana32's Avatar
Montana32
Montana32 is offline
Hello, I am new to this forum and could use some help identifying the Ford fan/hub assembly in my attached photos. You will notice that the hub has EAB casting number, so I assume it would be from a Mercury, perhaps a Merc truck. It might also be from a flathead 6 vehicle.
Can anyone help with the ID of this part?
It has a new bearing and shaft installed. The shaft was left long on the fan side rather than short with the sheetmetal plug cover installed so that the shaft would provide for centering of a later model fan. Other than that, it is as found.
Thanks for your help,
Steve
Old 08-19-2013, 05:49 PM
Montana32's Avatar
Montana32
Here are some additional photos. Thanks for looking and helping ID the part.
Old 08-20-2013, 02:32 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
I will bump this back up front for ya Bud.
Old 08-20-2013, 02:41 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
Looks similar to a 215/223/262 I6 fan hub (possibly to a car, but will work in a truck). EAB is just a prefix for a Ford part number. Doesn't necessarily means that it's a Merc.
Can you post all of the numbers found on the pulley and bracket please.
Old 08-20-2013, 03:23 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Interesting! I just made a similar piece for my v8, left the shaft long to center the fan blades. (Note that the shaft doesn't turn like on a water pump, so it can't be at all tight fit) I've never seen a bracket like that, looks vaguely Y-block to me, and the sheave says "S.C. Co." so an aftermarket item?
Old 08-20-2013, 04:10 PM
51PanelMan's Avatar
51PanelMan
The reason why I say it's from a 215/223/262 engine family is because that bracket looks absolutely similar to the one on the 215 engine in my 52.
Old 08-20-2013, 04:14 PM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
It doesn't have the wide pulley or long snout of the Y-block (truck) high-mount-fan. I think that it looks like it has Ford casting numbers. My guess is that it's either assembled using them or it's not aftermarket. Perhaps it's a narrow pulley (& close fan) mod for high-mount fan trucks? Might let one put a true damper on an older Y-block. Yes, I'm still guessing..
Edit - looking at it again, the fan spacing does seem to match up to truck high-mount fan spacing.
I assume that you want to sell it? If so, you might try sending me a PM. I might could make it work.
Old 08-20-2013, 04:56 PM
Montana32's Avatar
Montana32
Sorry, I am not trying to sell it. I have put it to use on something else and actually am looking for another one for my next project, a 1932 Ford pickup.
Old 08-20-2013, 05:00 PM
Montana32's Avatar
Montana32
Thanks for this info. I now have a new place to look. I got this one from a friend who has no idea of its origin. It uses the same shaft/bearing assembly as a flathead water pump.
I'm familiar with 223 inch sixes. Is the 215 a flathead six?
Old 08-20-2013, 05:24 PM
51PanelMan's Avatar
51PanelMan
215/223/262 are all inline 6 cyl overhead valve engines. 215 are 52/53. 223 are 54-60 or 61. 262 are from 60/61 to 64, I believe.
Old 08-20-2013, 05:59 PM
Montana32's Avatar
Montana32
Thanks! I will look at these.
Steve
Old 08-21-2013, 09:15 PM
Montana32's Avatar
Montana32
After seeing 51PanelMan's comments and helpful information, I did some more focused searching and I am convinced that this fan pulley/hub assembly is from a 1952 215 inch six (perhaps other years and 223's as well).
I would like to buy another one. If any of you have one to sell, please let me know. PM would be best.
Thanks, Steve
Old 08-21-2013, 10:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I can give you a bearing number for that, at least what worked for me. NSK 885586, about $20 at industrial bearing houses. (lower bearing below)
Old 08-21-2013, 11:31 PM
Montana32's Avatar
Montana32
Thanks for the info. I will definitely use that when I find one.
Old 08-21-2013, 11:53 PM
51PanelMan's Avatar
51PanelMan
Thanks, Steve
I was right???!!! What do I win??
Had one, sold it. May have another one somewhere.
I'm coming up with part # EAG8625A for this assembly. Checked on partsvoice.com and nothing is available. Search eBay for used.
Here's the assembly that I sold several months ago.
Quick Reply: Ford fan/hub assembly ID?
