rear suspension helps
greetings to all, I have a problem with the rear suspension of my F1's 56, I was confused to ask for the suspension to lower three inches since pedi one for years 53 and 54 and is shorter. Now I would like to use some of the leaves and send to the first here in Spain, but not as they would have to have. It is but to be understood and sorry for my bad English
Easy solution since you have the shorter springs would be to move the rear spring hangers 4" forwards on the frame to the 53-54 position. With the reversed eye springs you need to take the front hangers off and turn them upside down. You can also move them to the top of the frame for more lowering.
Note, The F1 was only 48-52, The 53-83 was called the F100 so your 56 is an F100 not an F1.
53, 54 rear springs were 4" shorter than 55-56 springs, all behind the axle. That is the only difference between the 53-54 frame and the 55-56 frame. I don't know if the other set of holes will work, but it is possible Ford kept drilling the old holes, if they are 4" closer to the front and match the mounts then yes.
When using reversed eye lowering springs like your new ones, you must remove front mounts, turn them 180 degrees then reinstall.
in the front suspension I have to change something?
kens65fb
09-21-2016 01:30 PM
capelo
10-27-2013 05:21 PM
Harrier
12-06-2010 04:17 PM
gijoe4500
06-30-2010 11:57 PM
ZZMAXX25
16
07-12-2005 04:31 PM
