Door lock issue - Ford Truck Enthusiasts Forums
Door lock issue
Old 08-19-2013, 03:35 PM
ScottSmith220 ScottSmith220 is offline
ScottSmith220 is starting off with a positive reputation.
Door lock issue
I am having a problem with a 2010 FX4 super crew rear passenger door. The door lock buttons in the cab, door key pad, or key fob will not actuate the door lock in question. I replaced the door latch assembly and that did not fix the problem. Can manually actuate the lock. Any thoughts before I take it to the dealer?
Old 08-19-2013, 05:21 PM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
Sounds like the actuator is gone. Not sure why you replaced the latch?
Old 08-19-2013, 08:18 PM
The latch assembly on the inside of the door. The actuator and the latch are one assembly.
Old 02-14-2014, 06:13 PM
69monster 69monster is offline
69monster is starting off with a positive reputation.
So I was searching for an answer to this exact problem, my truck just started doing the same thing. Did you ever find out what the problem was?
Old 02-14-2014, 08:04 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
bigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to behold
Check the wires that run between the body and the door to make sure none of them are broken from the door opening and closing. Im cant say if this is the problem but it is worth a look. It used to be a big problem in Dodge pickups.
Power Lock Problems 2000PrettyBaby 1997 - 2003 F150 2 12-23-2016 11:00 PM
drivers door lock hturner12 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 04-16-2016 12:01 PM
Problem door locks! dcchadwick Excursion - King of SUVs 15 03-06-2016 11:10 PM
Door lock rocker only unlocks Elmo154 Excursion - King of SUVs 1 11-17-2015 04:11 PM
Door stuck shut powerstroker100 1987 - 1996 F150 & Larger F-Series Trucks 9 07-10-2015 02:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
