477 Timing Gear Set - Ford Truck Enthusiasts Forums
477 Timing Gear Set
Old 08-19-2013, 03:24 PM
swglanville swglanville is offline
swglanville is starting off with a positive reputation.
477 Timing Gear Set
I am looking for a Timing gear set for a 76 F880 with a 475/477... So far I have found a listing for NAPA but they indicate none in stock and will have to wait for manufacturer... Piston Ring says they have the Crank Gear... Anyone knows of a good supplier that ships to Canada?
Still tearing apart the front on the engine to check on what parts are needed.. Still have the Harmonic Balancer and Timing Cover to pull.
It was running and died when it hit a bump and was towed Home... Crank turns, but Distributor and CAM are not...
Old 08-22-2013, 04:16 PM
Hmm, I see that Napa listed the timing gear set also compatible with Ranchero 6.6 L 400 CID V8, Did the Ranchero use a 401ci SD engine? Any Chance of adapting the Timing chain set from that engine to work on the 477 (Adding 2 more bolt holes to the cam gear)... NAPA AUTO PARTS NAPA AUTO PARTS 75 Ranchero 400ci Timing sets 1975 FORD RANCHERO Timing Set
Old 08-22-2013, 07:40 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Not related at all.
Do you have this thing apart yet? I think the SD motors are gear drive cams, no chain.
Old 08-22-2013, 07:54 PM
Yep, it is apart. Cam timing gear has a couple broken teeth, it sheared two bolts on the cam and the center pin on the cam. The crank gear is fairly worn and flattened...
Old 08-22-2013, 08:24 PM
Was it a chain or gear drive?
So the cam is damaged also?
Have you pulled to rocker covers? If so, see anything interesting?
As you are finding, these are antiques and not the kind that are going to finance your retirement.
Depending on a lot of other things, this may be the time to repower or upgrade the truck. Thousands into a rebuild of this motor.....only you can answer that.
Old 08-23-2013, 04:57 AM
big job's Avatar
big job big job is offline
big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.
A big A ouch. You say you can get a crank gear so I'd get it. Next the cam gear
couple broken teeth, thats no problem, going to need a new dowel pin. OK next
My concern would be trying to turn the camshaft by hand. In order for that kind of damage, something bad happened like swallowing a valve and a busted oil pump most likely would break the oil drive shaft. Or take off the valve covers
& look for bent pushrods or something. Think of people with "stuck or froze up
engines" which is always in these forums.. All it takes is just one stuck valve and you aint turning it over unless you break something! In your case I strongly beleive this is what happened. It takes tremendous force to wipe out teeth.
As far as the cam gear, for our shop, thats a common operation. We simply machine tooth implants & when done, you cant even see the repair. And yes its done old school with a shaper, mainly its expensive mill tooling to buy for a one off job in order to use a milling machine and that gets added to the customer so a shaper is indeed cheaper. Depending on damage, its only a $50 Job for implants "way cheaper than a dentist" !!
Old 08-23-2013, 02:52 PM
Pulled valve covers nothing obvious, Guess I'll see when I get around to extracting bolts from the cam and try turning it and then check the oil pump with a hex shaft down the dist
Old 01-15-2014, 12:29 PM
johns294's Avatar
johns294 johns294 is offline
johns294 is starting off with a positive reputation.
If you decide to replace the whole engine LMK. I may be parting out a 900 tow truck soon.
Old 10-23-2015, 04:52 PM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
"Next the cam gear couple broken teeth, thats no problem"
Big job, how can you replace and remachine gear teeth for $50?
Aren't these gears helical cut, and of involute tooth form...?
534 Rotating assembly Nolan Harris 401, 477, & 534 SD Engines 27 10-04-2016 12:05 AM
477-534 Ford industrial engines tlfrantz Large Truck 11 03-17-2011 01:31 AM
Super Duty 477 Wallingnuma 1961 - 1966 F-100 & Larger F-Series Trucks 5 02-14-2011 05:00 AM
477 Engine tech info norm426 401, 477, & 534 SD Engines 1 01-27-2009 12:15 AM
is a 391 as good as 477-534 lrd56 401, 477, & 534 SD Engines 2 09-23-2004 11:28 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
