linkage bushings - Ford Truck Enthusiasts Forums
linkage bushings
Old 08-19-2013, 10:27 AM
abyars111's Avatar
abyars111 abyars111 is offline
abyars111 is starting off with a positive reputation.
linkage bushings
Where can one find automatic shift linkgage & kickdown linkage bushings and the washer/snap piece that holds it together?
Every bushing I find is for a 3 spd manual transmission.
This is for a 390 with a C6. My kickdown rod is not installed so I want to install it. I have bushings on the trans linkage now but I'd like to replace them. This is the linkage from the trans up to the lever at the bottom of the column.
Old 08-19-2013, 04:25 PM
instig8r63 instig8r63 is offline
instig8r63 is gaining momentum as a positive member of FTE.instig8r63 is gaining momentum as a positive member of FTE.
I don't believe kickdown rod bushings are available. They are part of the kickdown rod.
Shift linkage grommets are available from Ford. Part # EOSZ-7341-B
Old 08-20-2013, 09:07 AM
abyars111's Avatar
Thanks for the part number. I found them by searching that part number:
C4/C5: Grommet, Shift, Manual Lever - Large - EOSZ-7341-B
Is there some kind of clip to hold the shift rod into the lever?
After seeing the part I know see someone installed the rubber bushings for a manual trans on my truck at some point.
Has anyone used some other bushing for the kickdown rod? Is the kickdown rod held on the lever by E-clips?
Old 08-20-2013, 12:48 PM
JEFFFAFA's Avatar
JEFFFAFA JEFFFAFA is offline
JEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant future
Aby. No clip for the shift. The E0SZ bushing is also a retainer at the same time. When you get it push it into the lever then push the rod in to it. No bushings in kick down rod. If it sways back and forth a bit no big deal.
Old 08-20-2013, 01:50 PM
abyars111's Avatar
OK. Thanks for the help!
Old 08-22-2013, 09:43 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by abyars111 View Post
Where can one find automatic shift linkage & kickdown linkage bushings and the washer/snap piece that holds it together?
C4SZ-7C484-A .. Bushing-Kickdown Rod-Lower / Obsolete
GREEN SALES CO. in Cincinnati OH has 8 = 800-543-4959 / NOS PARTS LTD in Waxahachie TX has 10 = 972-937-2201 / KINSEL L/M in Beaumont TX has 13 = 800-816-2894.
C5AZ-9C805-A .. Bushing-Kickdown Rod-Upper / Obsolete
NOS PARTS LTD has 8 / KINSEL L/M has 50 / GREEN SALES has 212.
1967/72: At the bottom of the steering column underneath the hood is the selector lever that the shift rod from the trans attaches to.
There are TWO DIFFERENT types of bushings used in this lever, they do NOT interchange. Verify which type you have.
One type is E0SZ-7341-B (replaced C8OZ-7341-A - C9TZ-7341-A - D5AZ-7341-C) which is a 'snap in' nylon bushing / Available from Ford.
The other type is C5TZ-7343-A which is a kit that contains a rubber bushing and nylon insulator (Used with A/T & M/T) / Obsolete ~ 100's available NOS
Left upper pic: Kickdown rod and etc. / Note location of 7C484 & 9C805 bushings
Old 08-22-2013, 10:00 AM
abyars111's Avatar
Thanks, NumberDummy. I was begining to get worried about you. I was afraid you were sick.
The truck's shift lever has the rubber bushing and nylon insulator installed on it now. I'll do a search online for C5TZ-7343-A
Old 08-22-2013, 10:13 AM
C5TZ-7343-A > >
NOS PARTS LTD has 9 / GREEN SALES has 20 / KINSEL L/M has 26.
371702-S .. "Wavy" Spring Steel Clip (used with C5TZ-7343-A) that when installed on the rod, flattens out...retains it in place (see pic) / Obsolete
GREEN SALES has 7.
A/T at lower right in pic. Notice pic shows rubber bushing and its insulator, does not show the 'snap-in' nylon bushing.
Old 08-22-2013, 10:23 AM
abyars111's Avatar
Green Sales has them as well as a few others. Green Sales says there is a clip that goes with them, part no. 379620S100.
NumberDummy is that the correct clip or are they needed for this application?
Old 08-22-2013, 10:24 AM
abyars111's Avatar
We posted at the same time. Yes, sir I need the wavy clip.
Green Sales didn't have any.
Old 08-22-2013, 10:39 AM
Green Sales has 7 = 371702-S AUTOMATIC trans.
379620-S100 = 3 speed MANUAL trans.
See post 8, I edited in the info, posted a pic of the little charmer.
Old 08-22-2013, 10:50 AM
abyars111's Avatar
Green Sales can't get 371620-S to come up in their system. I can't find it online doing a search.
Do you show that clip at any other parts dealers?
I can't find a diagram of the shift rod attachement to the trans.
Old 08-22-2013, 11:02 AM
Green Sales has 7: 371702-S
I typo'd the wrong part number, since corrected. See posts 8 & 11.
Only parts catalog pic that shows kickdown rod ~ See post 8.
Old 08-22-2013, 11:33 AM
abyars111's Avatar
they are ordered now
Thanks
Kickdown Linkage bushings and clips dmccorkle911 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-24-2014 05:35 PM
kickdown rod/ linkage dmar68137 1987 - 1996 F150 & Larger F-Series Trucks 2 07-19-2014 01:10 AM
1973 f250 at linkage clip rainerelliott 1973 - 1979 F-100 & Larger F-Series Trucks 2 10-01-2011 08:56 PM
kickdown linkage? SanFORDf100 1967 - 1972 F-100 & Larger F-Series Trucks 18 09-28-2008 03:32 PM
79 Bronco Automatic Kickdown & Throttle Linkage 79FordBlake 1978 - 1996 Big Bronco 2 06-27-2008 11:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
