1984 F150 axle ratio ? - Ford Truck Enthusiasts Forums
Old 08-19-2013, 09:50 AM
pecanguy pecanguy is offline
pecanguy is starting off with a positive reputation.
1984 F150 straight 6, auto has "17" on the door post information label for the axle code. I could not find this on the axle ratio charts that I found. Does anyone know what it is ?
Old 08-19-2013, 11:58 AM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
Is there still a tag on one of the bolts on the rear end/ if so it will tell the ratio, should be stamped next to the bolt hole, something like, 3.25 or 3.00.
Old 08-19-2013, 02:58 PM
Presently I can not get to it. It is on the ground under the truck.
Thanks
Old 08-19-2013, 03:33 PM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.
Old 08-19-2013, 06:02 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
17 is a 2.47 to 1 ratio rearend.
Old 08-19-2013, 08:55 PM
Dave F
Thanks for the info.
1984 f150/bronco LH axle support arm Jm1984 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 02-04-2016 06:43 PM
Gear ratios 1984 f250 j66b 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 11-05-2014 05:23 AM
Looking for axle ratio for 1958 F-600 with axle code 62 KLEO1480 1957 - 1960 F100 & Larger F-Series Trucks 2 03-02-2013 07:53 AM
!984 F-250 W3 Axle code? 00p225 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 10-08-2007 08:33 PM
1984 f-250 axle code victorcharlie 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 01-03-2004 07:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
