anyone deleted and installs to pass smog then removes
I would love to delete the emissions crap from the truck, but I live in a location that requires a smog check once a year. I was thinking of doing a DPF/EGR delete but would have to put it back on once a year to pass smog. My question is if anyone does this, how long, or practical of a project am I looking at each year. Is it a few hours, full day or what? I would think after a few years one would get good at doing the swap back to stock then back to deleted.
The EGR block off plates back to tube will take you about 15 minutes. It's just not a difficult thing to do. The DPF will take you a couple of hours and that is if you have a hand getting the dpf in. It's heavy and awkward to maneuver under the truck. I took mine off by myself and it was really a pain. You will likely need new hardware and bolts handy at the down tube after a while. I know mine were fine to reuse once, but I can see them rusting solid or seizing up.
Wow, that sounds like a pain in the ***. In my state many moons ago exhaust had to exit past the rear wheels. That meant my vette side pipes were illegal and if you got a ticket you had to get the car inspected. If the cops were smart and luckily they often were not they could require it be done at the motor vehicle department instead of just having a licensed repair facility sign off. It is good to have friends in the business. When Mopar came out with the Viper and couldn't register them in the state they sued and the state backed down. It was the only state. Man you do not need this pain in the ***. It is going to get really old.
I wasn't able to take the truck in for testing the first year it was required so the wife had to do it, but I believe so. According to the DMV webpage
"Light duty diesel vehicles undergo testing on a dynamometer. The technician will also perform an opacity test and a visual inspection of the emissions components"
You can run a tuner without deleting either as well (not your question, but maybe someone's question). If you buy an H&S tuner and want to run off the shelf H&S tunes (which are heavily tested and verified by H&S...most of us run these here), you have to delete both the EGR and DPF as that is how their tunes are written. However, if you go custom software via the MCC route (additional unlock code and you either write the tune or have a pro do it), you can delete one or the other along with a lot of other things.
on
EGR isn't bad... unless it clogs up, or the cooler fails. I know it was a really big issue with the 6.0l's (and a number of other diesel engines that were fitted with them when they first became an issue).
I am not sure how clogged up they can become with a 6.7 - but it is one additional component on the truck that is a liability to fail, that you can do without.
Will an EGR delete on its own significantly improve fuel mileage, reduce exhaust temps, or increase power or torque? Otherwise I'd personally just leave it. I'd love to not have to deal with the EGR, DEF, or DPF, but I'd deal with DEF all day if I could just get rid of that needless and costly DPF.
