1986 Ford Aerostar with 2.9 V6? - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 08-19-2013, 03:46 AM
FordMan1981 FordMan1981 is offline
FordMan1981 is starting off with a positive reputation.
Although the 1986 Ford Ranger compact truck and its Bronco II SUV counterpart had changed engines from the 2.8L Cologne V6 to the enlarged 2.9L version at mid-model year, then, why didn't the Aerostar follow in transitioning from the 2.8L V6 (which dates from 1974 and was used in both the Mustang II and the imported Capri) to the 2.9L V6?
I wonder if the Aerostar's failure to catalog the 2.9L in mid-1986 was because that model was obviously new for '86 (after having missed its potential sales run as a 1985 model, like the Taurus/Sable had)? But if it did, then the 2.8L (as well as the 2.9L that appeared in the 1986-1/2 Ranger/Bronco II) would've been deemed rare, because for 1987, the Cologne engine (in the Aerostar) was replaced by the then year-old, U.S.-made 3.0L "Vulcan" V6 that was introduced with the Taurus/Sable.
~Ben
86 bronco ii wiring harness YoungBroncoii Bronco II 2 04-25-2016 07:09 PM
2.9L 6 cylinder: Is it bad? coachnichols Bronco II 8 01-25-2016 02:30 AM
Tune Up and More Horse Power NEED HELP Lamie3030 Bronco II 1 12-03-2014 01:31 PM
1986 Ford Aerostar Engine/Pointing Timer Theo Varelas Aerostar 9 05-24-2014 12:17 AM
Sable electrical oddities Ford_Six General Automotive Discussion 8 02-28-2012 10:25 AM
Tags
aerostar, cologne, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
