How to disable electric fuel pump while cranking?
As the title says, I need to disable the fuel pump while cranking the motor for a compression test. I have the carb off the engine, so just an open intake at the moment.
I thought pulling the fuel pump relay would do the trick, but fuel started gushing out shortly after starting.
What's odd is that I'm using a heavy gauge wire to jump the battery (+) terminal straight to the starter wire on the solenoid, so that I can see the gauge without having to sit in the truck doing this blindly. I thought this would bypass all electrical accessories but I cannot seem to kill that damn pump.
Please help!
Please help!
It's on the I terminal. I will try this, thanks for the tip!
Also, I know I'm shooting compression values that are within 5% of each other, but what are appropriate or average compression readings for this engine? The first one I did before fuel started pouring at hit a solid 148 PSI.
I'm also at a high elevation, I suppose they will read slightly lower than normal, or does this not affect it?
I know this may be beyond the scope of my original question, but I'm curious if these compression numbers are considered decent for this model year engine (1985).
Cyl Number | PSI dry/wet
1. 147
2. 138
3. 139
4. 144
5. 150
6. 137
7. 120/160 (performed wet test on this one cause of the low #)
8. 130
Supposedly the engine has 97k and is original to the truck, but may have 197k; hard to tell.
Is there any surefire way to determine if the engine is original to the truck, or a replacement / reman unit?
1. 147
2. 138
3. 139
4. 144
5. 150
6. 137
8. 130
Lngbeard
15
04-29-2016 11:24 AM
F239141
04-21-2014 11:17 AM
BIGRED 7.3L
09-28-2010 09:57 AM
