Paragon install difficulty...help/advice? - Ford Truck Enthusiasts Forums
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.
Old 08-18-2013, 08:05 PM
mcguirehg mcguirehg is offline
mcguirehg is starting off with a positive reputation.
Ran into a couple of snags:
<o></o>
1) Installed the ramp into the rails. After setting therails in the truck noticed the clamps I screwed in were in the middle of theramps. So I had to unscrew the back of the ramp in order to slide the screwinto the bracket and then screw the ramp back in. The bracket to hold the railis now in the middle of the ramp. The directions said to install the rail clampin the middle of the steak of the truck side rail of the truck. My question iswill this cause problem with the operation of the cover? <o></o>
<o></o>
<o></o>
2) Second issue is aligning the cover with the truck. Allthe brackets that are screwed in are aligned with the top of the side rail.However, when I installed the spacers the rails require so many of the spacers,or washers. I ran out of washer so I decided that I needed to flip the bracketup to allow for less space. In doing this task the bolt snapped and so I ran toACE Hardware to replace the bolt and purchase additional washers for spacers.After returning it appears I still don't have enough washers to level the railsof the cover. I decided to call it a day....Is it normal to run out of spacersor am I doing something wrong....Any experience with installing this coverwould be helpful?<o></o>
Front hub problem Beaglebus Excursion - King of SUVs 4 02-17-2015 09:42 AM
Passenger plates on an F-350 Dually speakerfritz 1999 to 2016 Super Duty 16 08-08-2014 11:35 AM
Loose steering - complete front end rebuild ontarioford 6.0L Power Stroke Diesel 10 04-02-2014 10:24 AM
Custom Gauges PA F250 1973 - 1979 F-100 & Larger F-Series Trucks 17 08-28-2013 06:35 AM
I need help!! Rough Idle HPOP code Boomtrucker 1999 - 2003 7.3L Power Stroke Diesel 13 04-21-2013 01:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
