F-SuperDuty ZF
Old 08-18-2013, 07:26 PM
USMC0351fordtruckin's Avatar
USMC0351fordtruckin
USMC0351fordtruckin is offline
F-SuperDuty ZF
Will a ZF from a F-Super Duty work in my F-350 4x4
Old 08-18-2013, 08:07 PM
Daniel5.0's Avatar
Daniel5.0
Daniel5.0 is offline
How about some details? There were at least two versions of the ZF, a small block bell housing and big block bell housing. Don't remember if the PSD has the BB or a third pattern, someone will chime in.
Old 08-18-2013, 08:48 PM
USMC0351fordtruckin
My truck is a '97 F-350 PSD 4x4 and the F-Super Duty is a '95.F-Super Duties only came with 7.5 and 7.3 but I figured you didn't need to know the engine if transmission are the same from a F-350 to an F-Sper Duty with a 7.5 then they'll be the same if both trucks are 7.3PSD.
I heard that a transfer case will bolt to where the brake is I. The F-Super Duty's transmission but I don't know if that's bs or not thanks for any help
Old 08-18-2013, 10:20 PM
wtroger's Avatar
wtroger
wtroger is offline
7.3 and 7.5 do not share the same bellhousing pattern But can be modified to work. Also a zf with a parking brake on the tail housing is basically a 4x4 tranny meaning you can put a transfer case on it.
Old 08-19-2013, 07:20 AM
bashby's Avatar
bashby
bashby is offline
I bolted a 460 to my diesel zf. After drilling.
blue original idi holes
pink idi dowels
green 460 bolts
brown 460 dowels
red 460 starter.
Cut and pasted from another thread.. give type4 credit.
Old 08-19-2013, 05:28 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,102 Likes on 2,164 Posts
yes, a diesel ZF 5 speed out of a F-superduty will bolt into a 4X4 diesel truck. just remove the park brake assembly and bolt the transfer case on.
Old 08-19-2013, 05:58 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
What Tom Said.
A F-superduty trans is the same as a 4wd trans
JayzDaddy
01-29-2013 10:07 AM
R1CH1E
Large Truck
01-18-2011 02:52 PM
bsneed
09-12-2010 12:51 AM
Broke College Guy
03-27-2007 12:15 PM
Quick Reply: F-SuperDuty ZF
