Folding/Extending mirror lubrication
Old 08-18-2013, 05:28 PM
djousma's Avatar
djousma
djousma is online now
All,
Has anyone found a way to lubricate the fancy mirrors we have? On my 2011, the passenger side mirror stopped folding in this past spring, so I got out the silicone spray lube and sprayed into the hinges on both mirrors, and it took care of the problem.
Now, same side(passenger), it won't always extend, but if I manually extend/retract it, then use the button, it works.
Dont want to spend the big bucks on a new mirror, there has to be a way to get some lubrication in there. Was going to just try spraying the shafts where they go into the mirror housing to see if that reduces some friction.
Thanks for any advice.
Dave
Old 08-19-2013, 07:17 AM
Boomer23059's Avatar
Boomer23059
Boomer23059 is offline
I'm having the same problem with the driver's side mirror extension on my 2011. If I give it a push, it starts working (for now).
Old 08-19-2013, 01:22 PM
Armycop's Avatar
Armycop
Armycop is offline
Something my old man taught me, and still holds true today:
Does it move? NO Is it supposed to move? YES - WD40
Does it move? YES Is it supposed to move? NO - Duct Tape
Seriously, I used some WD40 on my driver's mirror and it's now quiet and smooth. Give it a shot.
Old 08-19-2013, 01:23 PM
2ndStroke's Avatar
2ndStroke
2ndStroke is offline
You guys just point it there and spray everything?
Old 08-19-2013, 01:50 PM
Armycop's Avatar
Armycop
Armycop is offline
LOL, no just at the hinges and in between the arms. Almost everything...
Old 08-19-2013, 03:08 PM
2ndStroke's Avatar
2ndStroke
Lol, I didn't quite mean it like that, my bad. But I am a "more is better" kinda guy....
I'm gonna add this to my PM
Old 08-19-2013, 04:44 PM
Chad149's Avatar
Chad149
Chad149 is online now
WD-40 is pretty harmless to most materials. The only thing I can think of that might harmed is if they use any sort of adhesive to hold the glass in.
Old 08-19-2013, 06:22 PM
Firekite's Avatar
Firekite
Firekite is offline
WD-40 is a mix of solvent and light lube that is meant to displace water (moisture). It does that very well, but it attracts dust and grime to it very badly, which will result in a build-up on those moving parts.
I would probably try something else first, probably a "dry lube" spray, generally either
teflon teflon
(or
teflon multi-use teflon multi-use
, not sure which would be better),
cerflon cerflon
, or even
graphite graphite
Old 08-19-2013, 06:24 PM
Armycop's Avatar
Armycop
Armycop is offline
Yup, there's those as well. Any of them should work.
Old 08-20-2013, 06:42 AM
djousma's Avatar
djousma
yea, I have tried silicone spray, did the trick on the folding problem. I am just out of that at the momet.
Old 08-20-2013, 09:25 AM
Firekite's Avatar
Firekite
Firekite is offline
I would avoid silicone spray as well, as it will still collect dirt and grime just as bad as oil-based lubricants. It's not that it won't work, but over time it's harder on things and will have to be done more often.
Old 08-20-2013, 09:59 AM
djousma's Avatar
djousma
ok, will try that too. i have graphite spray lock lubricant.
imlowr2
24
11-09-2008 07:59 AM
reddogracing
1999 to 2016 Super Duty
10-04-2008 07:02 PM
dkoenig
1997-2006 Expedition & Navigator
08-17-2008 01:38 PM
IRULE
1997 - 2003 F150
04-03-2004 05:34 PM
john z
01-21-2001 12:17 PM
Quick Reply: Folding/Extending mirror lubrication
