newer 5.4 spark plug problems - Ford Truck Enthusiasts Forums
Old 08-18-2013, 11:38 AM
capttwb capttwb is offline
capttwb is starting off with a positive reputation.
I've just heard the late 5.4 engines are having a problem with their spark plugs welding themselves to the aluminum heads. Anyone know of a way to prevent this? How much does a Ford dealer usually charge to replace 5.4 engine spark plugs? I heard it is real expensive.
Old 08-18-2013, 12:03 PM
Road Ranger's Avatar
Road Ranger Road Ranger is offline
Road Ranger is starting off with a positive reputation.
I'm surprised no one has commented this as I gather it's a potentially serious issue if they have to be drilled out (by removing the cab?!)....or maybe I'm not using this forum properly and have missed the replies to this thread. Anyways, I bought my '04 F-150 5.4L in July '11 and only later learned about this standing issue with those engines. I understand you should remove and service the plugs every 50Kms/30Mi. Everything went well when I had mine serviced last year. My truck now has 176,000 kms on it and I'll be checking/replacing the plugs again at the 200,000 Km mark unless I learn otherwise before then. HTH.
Old 08-18-2013, 12:22 PM
Quote:
Thanks for the info. Road Ranger. Did you change your plugs yourself or did your dealer do it?
Old 08-18-2013, 12:51 PM
Well capttwb, I had the dealer do it because of that stomach-sinking feeling when I break something and have to do the job twice and for twice as long! Unfortunately, I don't remember how much that cost because there were two or three items done during the same service visit. I've been told that it's hellish expensive if one of those plugs breaks, something in the $1,500 range?
Old 08-18-2013, 01:00 PM
canstacker canstacker is online now
canstacker is starting off with a positive reputation.
Do a search, this has been covered many times. There is a tool that can remove most broken plugs. The new plugs are one piece and don't break in two. 04-07 are the problem years.
Old 08-18-2013, 01:56 PM
tdbudman tdbudman is offline
tdbudman is starting off with a positive reputation.
Quote:
There's a TSB out on this too. Make sure you warm the engine SLIGHTLY before you remove the plugs. If they don't break loose under "normal" tension hit them with some blast off or comparable, (Ford makes one for this) and let it do its work. Look at the bright side. If you snap them off and worst case scenario you have to remove the heads.....You'll have new head gaskets!
Old 08-18-2013, 02:44 PM
Awriiiight !!! Now I feel better about any potential spark plug issues. Thanks, guys.
Old 08-21-2013, 02:43 AM
jeremy1 jeremy1 is offline
jeremy1 is starting off with a positive reputation.
I did mine at 195000 Kms and every plug broke. I knew of this problem and bought the Lisle tool kit ahead of time. It takes about 10 minutes per plug to extract the broken pieces. I sprayed the plugs with carb cleaner and let it sit 24 hrs. You want to make sure that you don't use too much torque removing the plug. It is possible to damage the aluminum threads. Also, Aluminum is softer hot and I wouldn't do it with the engine hot
There are a handful of YouTube videos if you are interested
Old 08-21-2013, 06:03 AM
Thanks Jeremy.
Old 08-21-2013, 06:05 AM
So how about the 4.6 engine? (2004-2007) Same problem?
Old 08-21-2013, 12:44 PM
4.6 engines do not have the plug problems, only the 5.4
Old 08-21-2013, 01:44 PM
My understanding is that it is the 3 valve engines and the 5.4 is more of a problem than the 4.6
What 5.4 engines spark plugs break? Coreycss2 Modular V8 (4.6L, 5.4L) 7 09-11-2016 09:01 PM
Spark Plug Coils makthenif 1997 - 2003 F150 6 04-24-2014 09:49 AM
5.4L spark plugs gogreenwave Expedition & Navigator 11 02-27-2014 10:53 AM
Updated MotorCraft Spark Plugs? RISUPERCREWMAN 2004 - 2008 F150 0 02-15-2011 08:23 PM
5.4 spark plug blew out of head oxfordsunoco Modular V8 (4.6L, 5.4L) 2 11-02-2003 10:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
