94 ranger 2.3 pleas help - Ford Truck Enthusiasts Forums
Old 08-17-2013, 09:48 PM
stevesecoy stevesecoy is offline
stevesecoy is starting off with a positive reputation.
Okay Heres The Problem, Im Getting Fuel To The Rail, Getting Fire, But My Truck Wont Run.If I Spray Ether Into The Intake It Will Run As LOng As Im Spraying But Dies When I Quit.. I ReplCed The Fuel Pump, The EEc,Both Relays And ChEcked All Fuses! Please Any Suggestions
Old 08-24-2013, 08:21 PM
thunder74-79's Avatar
thunder74-79 thunder74-79 is offline
thunder74-79 is starting off with a positive reputation.
sounds like your injectors aren't firing.
Old 10-02-2013, 10:04 AM
Stinky1 Stinky1 is offline
Stinky1 is starting off with a positive reputation.
Have you checked your fuel pressure?
If you have pressure, then your injectors ain't working...like Thunder said.
"Something" tells the injectors to get with it, get working, NOW!!! It could be the computer, it could be a sensor, whatever it is...start there.
Start then dies and no start Jesse73iditurbo Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 12-05-2016 10:01 PM
94 f150 fuel filter fordka 1987 - 1996 F150 & Larger F-Series Trucks 3 06-06-2014 03:37 PM
need a bed sprayed Kris Dickson Missouri Chapter 24 12-01-2013 01:30 PM
Start problems/1986 F250 DarolWester 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 32 08-13-2013 07:59 PM
1988 F 350 fuel problem jayro 1999 to 2016 Super Duty 4 06-24-2005 11:56 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
