2wd front lift kit
Old 08-17-2013, 04:52 PM
TheGageinator's Avatar
TheGageinator
TheGageinator is offline
2wd front lift kit
I want to get some of those coil spring spacers for the front of my 94 f150. would you guys think 2.5 inches is too much, should i go with the 2 inch blocks? also, do you know what camber kit i should get? i put some springs from a 3/4 ton truck on, and there was no change in ride height.
i had a 1992 explorer that i put the 2 inch coil spacers on, and it through the camber off very bad. i didnt know i could get adjustable camber kits so i just took the lift off.
Old 08-17-2013, 04:54 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
are you trying to jump it?
Old 08-17-2013, 05:01 PM
TheGageinator
why would i jump a 1994 f150? im trying to get it to sit level. the front end needs to come up at least 2 inches if not more to be level. plus im putting 1.5inch blocks in the rear
Old 08-17-2013, 05:02 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
it wont be level when you haul a load. thats why they sit higher in the rear, because they are made to haul stuff. not a kia it says in the manual i belive.
Old 08-17-2013, 05:23 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
that's the idea, but I spenda lot more time not hauling than I do hauling and my truck looks a lot better raised a little.
Old 08-17-2013, 05:31 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
my buddie had a 82 f250 with a 460 and man he would jump that thing, it had the TTB 4x4 front end, couldnt break it!
Old 08-17-2013, 05:32 PM
TheGageinator
Haha no way??!! That's awesome. Im going to lift he back also so it won't sag and look funny
Old 08-17-2013, 09:06 PM
TheGageinator
So any ideas anyone??
Old 08-17-2013, 09:22 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
Just get coil spacers off ebay and adjustable camber bushings from Bronco graveyard or something and make it happen. It's a quick job, took me less than 2 hours to put them in.
Old 08-17-2013, 10:15 PM
TheGageinator
So any adjustable bushings will work? Ok. I didn't know if there was a specific degree camber set that I needed
Old 08-17-2013, 10:25 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
You won't know the degree until you get it put together. Unfortunately they're all different so it requires adjusting.
Old 08-17-2013, 10:34 PM
TheGageinator
Ok thanks man. I found those adjusters. Do you think 2.5inch would be too much for the stock parts to handle? I know 2 inch would be fine. Plus my springs are sagging for sure.... Maybe I'll go with the 2.5 lift spacers
Old 08-17-2013, 10:41 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
I've never seen 2.5 spacers. I'd be worried about everything being way off at that point, the pitman arm wouldn't reach among other things. If you're really wanting to get her up in the air right, I'd suggest saving up and just doing a 4" lift kit.
Lifting a truck can be complicated so just remember the more lift you go with, the harder it will be to keep properly aligned.
Old 08-17-2013, 10:55 PM
TheGageinator
Thanks for the help man I really appreciate it. That's the feedback I was looking for. I may just have to save up for a full lift
Old 08-17-2013, 11:10 PM
Jarryd's Avatar
Jarryd
Jarryd is offline
I may jump up to a 4" lift in the future and throw in some 35s but I have other priorities right now unfortunately.
Quick Reply: 2wd front lift kit
